I also see no need for the rear pocket. Just another difficult to clean place place to collect dust, spilled soda, change, etc. I vote to delete that. The rest is excellent.
Okay, thanks man. What if you elevate the insert a little bit? That would make the lid higher than the cushion edge and allow you to push forward a little bit. Even a 1/4" would do a whole lot. All just suggestions.Yes, but it's right up against the lid. I just can't move the cup hole any further foward. The plastic insert is right up against the bottom of the front edge of the hole and it's only .1" wall thickness right there. I will get some pics of the 44oz. cup installed in the next few days.
I don't think the insert in the back will be too bad to clean since the entire insert is removeable. You can just lift it out, rinse it off and stick it back in there. This CAN be screwed into place using the factory screw in the bottom and some 3M adhesive but I just don't see any reason why you would want to do that. It is VERY secure with zero hardware and adhesive. My design has about a 1/2 degree wider taper so that as you push it into place it wedges itself in. It becomes nice and snug right as it hits bottom. It's not going anywhere.I also see no need for the rear pocket. Just another difficult to clean place place to collect dust, spilled soda, change, etc. I vote to delete that. The rest is excellent.
Not a bad idea. Let me get some pics of the 44oz. drink installed and if it looks too tight then we can look into moving the insert up and foward.Okay, thanks man. What if you elevate the insert a little bit? That would make the lid higher than the cushion edge and allow you to push forward a little bit. Even a 1/4" would do a whole lot. All just suggestions.
the width of my phone is 3 1/16th". there is a little bit of wiggle room left to right but nit much. You might be able to squeeze a phone up to 3 1/8" inch wide. That would be the max width and a snug fit. please post up what the width of your phone is so others will know if their iPhone 6 plus will fit or not.What's width of your phone with case? I have iPhone 6 plus with a case and wondered if it would fit. Thanks
