Ok...some of you know, I am new here, I know how to use the "search" button, but I can't seem to find a specific answer to my question.
There seems to be a lot of questions about speaker sizes, depth of speakers, etc, so I won't bore you with that question, I'm simply going to pull a few speakers from various positions and begin my search for speakers that possibly fit behind the stock covers without a lot of modifications...sound is important, but I am not an audiophile so even something mid quality should suffice...I will report my findings for those of you wondering what currently is available and capable of fitting behind the stock covers...hate the idea of putting aftermarket speaker covers on my doors but it might be only choice.
On to my question...or concern...the way I see it my truck (95 LC) has a head unit and 9 speakers...not all of which work but I have identified 9 speaker covers. Two below the dash, two in the front doors, two in the rear doors, two up high in the rear and the 9th in the rear side panel...suspecting this is the factory subwoofer.
When I replace my head unit, I am imaginging I will need to get a wiring adaptor...by simply plugging this in to the head unit and replacing all speakers (as some are blown or at least aren't emitting any sound) will the system come back to life? Isn't there a factory amp for the subwoofer? If so, should I disable it and add a new amp and subwoofer? Should I disable or choose not to use the other 8 speakers...if I choose to use them will they all work with a simple wiring adaptor? Does anyone know the best place to get an adaptor? Where is the factory amp located (if I do indeed have one)? Am I better off disabling some of the speakers...I've read where I would be spreading the power too thin.
My new head unit is a Pyle Double Din AM/FM/CD/DVD player with 80 watts per channel (four channel). I am a do-it-yourself guy, but not if I am going to go crazy figuring this thing out. Any ideas or help would be appreciated...just not sure what to do at this end. Thanks.
