With recent problems with the EMS Powered folks (best I can figure they basically got kicked of the site for scamming people or being non-responsive?), is it back to the drawing board for finding a well made turbo kit/reliable vender?
They(EMS) are back and have responded in the thread in chat.
It is a good looking kit, I am curious for someone to try it. It is a big turbo for the application but to run low boost and provide enough volume it needs to be pretty large, the only downside to that is it will have turbo lag, upside is that it can potentially work with stock fueling since it won't be boosting until open loop.
If you want to run this past stock fueling and tune, you would need a computer of some sort, injectors and possibly fuel pump. A turbo this size can easily lift the head if turned to max potential.
A bare minimum for me would be a head gasket R&R, so that's about $1200 if you don't get crazy with the "while I am in there tasks" then you should be good for quite a while at low boost and stock fueling. But if you have plans to turn the boost up at some point you will want to change the head studs ~$250, have the head gone through ~$600-800, and then at that point you need injectors ~$350-600, fuel pump $180, and a computer $600-1800.
Annnd just because I am a hater, have about $1300 set aside for when that Chinese turbo dies and you need another one
