murf
Lifer
- Thread starter
- #21
First, the 3 quart container was installed adjacent to the washer bottle and mounted to body with an aluminum strap using existing bolt holes in the fender. This allows the straight nozzle out of the bottom some room to circle back around. The Snow high volume pump is mounted at the pack of the passenger fender near the firewall. Currently I am running with the 175ML/minute nozzle with the pump set at 200 psi. This new style Snow pump is adjustable from 150psi to almost 400psi. After playing around with different nozzle sizes and pressures, this setup gives me the best balance of performance and fluid usage rate.
I have the system set up for normal day to day easy driving, so the idea is that this system will not be activated very often. I have needed to adjust the “kick-in” point. Currently it is kicking in at approximately 70% throttle. After several days of testing at 45% throttle activation and using up the juice with my foot, the usage rate is at a more reasonable level if I actively keep my foot out of it and stay with the new setting.
