Hi all,
I think the smog pump is busy seizing up on my 2F. The fan belt sometimes starts screaching for short periods although it has enough tension.
This pump is not in use and the input is shorted to the output by a hose.
I would like to remove this pump but I also understand that it is needed as a pully to tension the belt from the crank to the fan.
What suitable pulley assembly can I replace the pump with and where should I try and find it (off which motor etc.)?
Thank you very much for all the great help in the past!
Kind regards
Bernt
Kind regards
Bernt
