Thank you and great build thread
Let us know what we can help with!
The preload is either based on a crush sleeve or a shim set. If it's a shim setup, you are golden. If it uses a pinion crush sleeve (lots do), then it's more of a PITA. People say there is nothing wrong with just retorquing the nut. But to me that seems like a temporary measure. I'd be more likely to do it in the front. Also, you can pull the crush sleeve out, measure it, and then replace it with a solid spacer and shims.
Replacement is kind of a pain, but worth it imho.
