I'm at a crossroads in the rebuild of my 1982 FJ40. I intended to have my H42 rebuilt, however the transmission shop has informed me that the 2nd gear syncro is toast. The only way to replace this part is to order the whole assembly. Of course the part has long been discontinued by Toyota, so all that remains are used assemblies. I'm a bit hesitant to spend all this money rebuilding a transmission to install a used wear item. Since I have a late-model 40 with the cross brace and rear parking brake, the H55 is an excellent candidate for a transmission swap with minimal modification.
My original intentions had been to convert my 40 to SOA using the stock 40 springs. But I'm afraid SOA + H55 will create a nasty drive shaft angle. Does anyone know if this combination is possible? Would I need to flip the springs and move the axle back a few inches to lessen the angle?
