Build Yet another New LC Owner
In the never ending story of my truck we come to this chapter…
Wheels and tires
Went with method racing beadlooks and bfg 37” tires in the km3 flavor
Annoyingly they don’t really appear much bigger than the 35” tires I replaced…but they do look in proportion and initial testing shows no rubbing…
Just added some new oem splash guards…so naturally while I was in there I check on the front end…
Not too bad for a daily driver
Only the good stuff…can’t say I don’t support our vendors
So naturally it’s time to change out the belts…pah! 25 minute job!!!
Of course my adjusters wouldn’t give me the slack needed to slip on the new belts…so while I was “in there” the little alternator pulley from Mr Photoman was mocking me from the garage…so off comes the splash guard, off comes the negative terminal…off comes the power steering reservoir and out comes the alternator…
A good scrub down and blow dry and I remove the old pulley and install the new one…reinstall everything and am now cleaning up…so something that started as an hours work max became an entire morning…hahaha
Fancy damper from Dobinsons via DeltaVS…
Also replaced my destroyed sunroof garnish that @cruisermatt hooked me up with…a quick blast of oak colored paint and in they went…
Slowly chipping away a little tasks that matter only to me…next up will be the steering box frame reinforcing from delta and then mount up the 105 box along with a new rag joint and new coupler…that should close the chapter in steering.
Then comes some interior replacement parts like ac registers and a new cluster lense along with window runs, weather strips and window belts…
Last but not least will be new rotors and pads…simply because they are sitting on garage floor mocking me…
Dollars to donuts I’ll wind up getting body mounts and doing that chore
Well that’s another task done…new skin on the steering wheel…I’m far from Suzy homemaker so forgive the sewing attempt…but for $65 on Instagram I thought it was worth a shot…
Sewing sucks…and I lack the patience to do it
Last chapter regarding steering…
delta vs frame plates and a fzj105 steering box…coupled with the dobinsons adjustable damper and the marlin crawler drag links with new joints throughout…steering should be behind me.
Parts arrived and parts on order…even managed to install a couple and even take the truck out to the woods…
Seats from Scheelman on thier way next week along with timbren bump stops…some maintenance parts from cruisermatt…
Gonna be busy this next couple of weekends
3 big boxes arrived today from California…courtesy of @TYM4FUN…another chapter to be added to mighty whitey…
Power and solar distribution relocate under the hood
New front grille with turbo badge for incoming install
Mountain hatch tailgate panel to replace carpet
New oem carpet
Rework of in cab electronics and drawer system…
Depo headlights JDM clear corners and 91-94 lower apron alone with led colight fog lamps
