This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
A few additions and revamps.
Keep watching there’s more to come…
When I'm good...Noone remembers,
When I'm bad...Noone Forgets.
97 Fzj80 Turbo
2019 UZJ 200
I hate money it appears…
Big thank you to @ jcardona1 for the new shiny headlights
97 Fzj80 Turbo
2019 UZJ 200
Looks great, where did you find the red “turbo” badge? Would you mind showing a picture of the back of the grill? Thanks.
Turbo badge was from
eBay by a fellow mudder bh3 or b3h
Will snap pics this afternoon of rear of grille
97 Fzj80 Turbo
2019 UZJ 200
Turbo badge was from eBay by a fellow mudder bh3 or b3h
Excellent, thank you.
97 Fzj80 Turbo
2019 UZJ 200
Front facing camera installed…
97 Fzj80 Turbo
2019 UZJ 200
Holley retrobrights installed
97 Fzj80 Turbo
2019 UZJ 200
Headlights are mounted up…
Big thanks to jcardona1 for his assistance in making this happen so smoothly.
97 Fzj80 Turbo
2019 UZJ 200
Reworking my 12volt needs…replacing 2 27 grouper discount auto agm batteries with a T max manager with 2 odyssey group 31 agms with charging duties handled by the blue sea systems ML ACR…all cabling is 0 gauge…starting battery is isolated from second battery which provides all house circuits with juice…all switching is via 2 garmin power switches and the alternator is a sequoia 150 amp with a under drive pulley and a Photoman bracket.
97 Fzj80 Turbo
2019 UZJ 200
So I’m basically a hybrid now…tight fit and some cable rework is necessary to clean things up…
Shouldn’t be hurtin for 12volts now…150 amp sequoia alternator with a under drive pulley…supplemented by a 90watt solar panel on the hood.
97 Fzj80 Turbo
2019 UZJ 200
The ride so far…more to come
97 Fzj80 Turbo
2019 UZJ 200
So I installed the new shocks which accommodate 4”-6” of lift…
Will attempt the delta skid plate next…
And went out into some of floridas boonies on a work mission…
Also added landcruiserphils battery hold downs to the dual odyssey 31ms
97 Fzj80 Turbo
2019 UZJ 200
Why ain’t the turbo on ?!
1994 FZJ80 Part Timed,Triple Locked, and V8'd
1973 FJ40 V8’d
2003 Chevy Express 4x4 Shaggin’ Wagon
i'm ok with it, keep beating on that flashback button
97 Fzj80 Turbo
2019 UZJ 200
LeD conversion on the outer euro beam lights and hid conversion on the inner pencil beams…minimal draw
97 Fzj80 Turbo
2019 UZJ 200
Just read through your whole thread very nice rig
97 Fzj80 Turbo
2019 UZJ 200
The tally so far of parts and pieces to this truck
OEM full exhaust
New Engine
OEM Mounts
OEM Radiator
Land tank Blue hub
OEM Water pump
OEM Power steering hoses and cooler and reservoir
OEM Coolant overflow bottle
OEM Washer wiper bottle
OEM Harness
Marlin crawler HD steering links
White line rear sway bar
White line front sway bar
555 Tie rod ends
Dobinsons Panhard rods
Dobinsons upper rear control arms
Dobinsons springs c97 145vt c97 144vt
Dobinsons adjustable steering damper
Icon 2.5 shocks
Method racing NV305 17”wheels in bronze
BFG KM3 12.5x17x37” mud terrain tires
Slee shortbus bumper
Slee washer relocate
Slee extended brake lines
Slee rear bumper
Slee 2” trailer hitch
Slee front sway bar drops
OEM suspension bushings
Arp hub studs
Arp knuckle studs
Wits end nut huggers
Rcv cv axles
OEM rotors and pads and parking brake
OEM Calipers
Koyo Wheel bearings
Pioneer nex 4400
Front facing camera
Rockford fosgate speakers
Solve function tweeter pods
Kicker 700 watt amp
Icom ic7000
Icom ah as tuner
Icom ah-2b antenna
Diamond 2m/440 antenna
Wilson WeBoost overland antenna
Garmin Tread overland edition
Garmin powerswitch
Garmin powerswitch
Garmin bc50
70mai dash cam
Viair OBA
Solve function clock ram ball mount
Gentex mirror
Wits end mirror mount
Inti roof rack
Napa awning
Sequoia 150amp alternator
Photoman pulley
Blue sea acr dual battery system
Dual odyssey group 31 batteries
1/0 battery cables
Warn m8000 winch
Warn wireless winch controller
Synthetic cable
Factor55 ultra hook
Factor55 hawse
OEM fender splash guards
OEM hood liner
Land tank Lspv relocate kit
Yodateq gull wing side windows
LCP HD sway bar links
LCP aux cooling fan
LCP sway bar disconnects
LCP HD sway bar brackets
Yodateq antenna mounts
UZJ 100 sub tank
OEM Dual tank filler neck
Scheelmann front seats
Planted seat brackets
Mosley replacement leather
Weather tech floor mats
OEM hood
OEM lower front apron
HV2A transfer case with sumo 10% ud and 3:1 low gears
Land tank front cv driveshaft
Land tank rear driveshaft
OEM fzj105 steering box
OEM rag joint
OEM steering coupler
OEM shift knob
OEM T case shift knob
Delta frame reinforcement
Delta front control arms
Delta panhard rod bracket
Delta beefcake skid plate
Waterport
Bouge rv water heater
Cascade designs solar panel
Victron Solar controller
94 center console lid
Wits End turbo kit
Led Colight fog lights
Apex design compact hose reel
OEM quad headlights
OEM early model grille
OEM under hood rubbers
Holley retro bright headlights
Hella rallye 4000 rack lights
Aussie hid conversion
Led euro beams
MIC tuning volt meter
And still not enough to qualify for the cool kids club!!!
97 Fzj80 Turbo
2019 UZJ 200
97 Fzj80 Turbo
2019 UZJ 200
