Build Woodrow, the 60 - Tilda Bogue Service Station
Chipping out lots of grease caked dirt from somewhere out west. I “think” all the leaks are stopped. I’ll be hosing down this thing with Fluid Film after I finish working.
4* shims on all of the lifts I do via @orangefj45
Stabilizer
Fender Skirts ordered from Trail Tailor. IMS shocks and new longer sway bar rods
Kendas in place and it’s on all 4
Long day. Whipped.
It’s like the land of misfit wheels down there lately, amongst other improvements they seem to always leave properly fitted!
Plus, I like when folks fit ugly wheels on their cruisers, it usually means the stockers end up posted cheap on the second hand market because they have no value to them!
Luckily the people I work with either agree with me or let me bully them on proper wheels and tires
I cannot imagine the set it came with required much strong arming to ditch. Good Lord.
I’m glad the owner could see though them to pick up a solid 60. It was hard to see past them
How was the fake woodgrain faked?
It’s a decal.
I like it, shows character, not your typical contact paper Wagoneer woodgrain!
Looking forward to watching the progress!
Added some hood struts and took the 1 3/4 receiver off. That thing was baked on. I dug a 2” frame mount out of my container and dropped it at powder today.
Now I spray.
Now I spray.
Living in the rust belt, I have treated my LC200 with either Fluid Film or WoolWax since bringing it into this environment. Love the Fluid Film product and find it hard to believe that someone hasn't franchised it up here in northern WI / Minnesota.
I have a 1982 FJ60 that will never see a salty road again; however, there is surface rust on the frame. I purchased some POR15 degreaser, metal prep and rust preventative paint that I was planning on applying this winter. Any reason why you're not taking that route vs Fluid Film? I know POR15 is a mess to work with and the prep time etc...
Fluid Film over a clean yet surfaced rusted frame is a 1 hour deal versus a 1 week deal.
In the end, both will protect the Frame and look great. Fluid film also creeps where POR and paint won’t.
I’m doing a mix of POR, Paint and then a final coat of Fluid Film on an FJ40 I’m building.
I really like the thin coat the air gun application applies versus the cans.
This is what the frame looked like. Dry aged.
The other good thing about Fluid Film is you can soak all the body mount rubber and hoses and such while you are going to town and it won’t hurt just help.
With those hood struts, did you have to re-tap the lower mounting hole (the old spring mounting hole) ?
The Amazonia 4x4 kit like that isn't available anymore and I never found out if were supplying a metric thread pivot or not.
Beautiful build. I've never seen the wood applique on a 60 before. I like it. Hope it cleans up nicely.
This kit is off Amazon. M8 studs. The only thing you need is 2 M8 rivnuts for the hood side. Bottom goes in spring holes.
Waiting on parts to fire and drive so I’m switching gears
Before
After CLR
After Groits Yellow correction and wax
There is paint under there
