Cruisers and Co
Supporting Vendor
- Joined
- Mar 30, 2023
- Threads
- 7
- Messages
- 873
- Location
- Westminster, Colorado
- Website
- www.cruisersandcompany.com
This one is way easier and yes you can remove the thermostat if you’d like and then vacuum out the shavings. Any shavings missed will likely just end up trapped somewhere. As long as there isn’t a lot left behind there is nothing to worry aboutThis is exactly what I've done. I think after 1000 miles I'll drain the oil, then again after another 1000. Might be overkill, but it would only take one of those shavings being sucked up the oil return to get into a cylinder and ruin my month.
Glad to hear you haven't had any issues. I think I did 3 cans of brake cleaner, and 2 quarts of oil-- one from the top over the valves, and a second one via syringe from the outside of the newly drilled holes. Inside, I did q-tips, pipe cleaner brushes, and my fingers. I can't feel anything more in there.
Crossing my fingers.
In the install video, I see Johnny drilling the thermostat housing for a coolant line fitting and it looks like I'll have the same problem there... Was that as big of a problem? I'm assuming I can just remove the thermostat housing and pull the shavings out easily there.
