Which year is less rusty?
The later models used thinner sheet metal, so they're more prone to rust through. I think they switched over around '77, but I could be wrong. That being said, geographic location probably has more to do with how rusty the truck is going to be.
I don't keep mine in a garage, but I wish I could. Aside from the benefits of keeping it away from the weather, it would make it so much easier in the summer. Since I generally only drive it on nice days anyway, I could just leave the soft top down all the time.
edit: I guess it's '76. :doh:
I think geographic location has more to do with the rusting than any other factor. I'm not saying they may have used better metal in 68 - 74, than 76 - 81 but from what I've seen the geographic location has the main say so in the health of any older vehicle. I don't think you can go wrong with any FJ40 I like them all, and Toyota built everyone to as durable as the next. Everyone has their model preferences for their own reasons. The same logic applies for any classic automobile. I have a friend that buys and restores 50's Chevy cars and trucks. He pays more for Arizona and California vehicles than anywhere else. They tend to have less rust, and aren't subject to winter salt roads, Gulf Coast salt air and humidity, extreme rain conditions. Where the truck was kept and what it was used for plays a big part in the health of the vehicle. If it was stored in a garage, barn, etc they would be less subject to the elements. Best advice is pick out the things that you like best about a specific year model and persue it. You can't go wrong with any year model; they are all great rigs. :)
1974 does OK
I don't remeber where I read or heard this information or if some bloke in a pub told me. But I am under the impresstion that somehow the process used to prepare the body sheet metal changed in 79, and not for the better. My understanding is that these later years, post 79, are more apt to rust than the earlier model all things being equal.
It's not just the process; the later years have thinner steel. 18 gauge as opposed to 16, I think.
X2...and Welcome to MUD.
Location will be a big issue, and yes the earlier years had thicker metal which just means it takes longer to rust through. If you are looking for one, but one that is clean. Besides location, how you take care for it will be significant as well. At the end of the day though, these vehicles are 30 to 40 years old and rust will catch up to them...it is inevitable. SO find one and have fun!!:cheers:
Pete
My '78 BJ 43 (RIP) was so rust that the complete roll-over bar felt through the body when the truck was around 20 years old. The '86 HJ60 I have now seems to hold much better against rust, but the HJ was completely tectiled by the PO.
Anyway, as long as your chassis is OK, body panel rust should only be an esthetic concern (at least when your local goverment has no problem with it).
It's not just the fact that it's thinner, rather it's a different kind of steel altogether, it's called HSS (high strength steel – not to be confused with High Speed Steel used in drill bits and taps) by the automotive industry. More carbon and therefore more likely to rust. The idea was to use a thinner and lighter material with the same strength and the thicker and softer steel. I used to have a Toyota Factory Service manual for the dealership body shop's that described this in great detail. It also discussed how the mig process was ideal for HSS and said not to try to gas weld it. In general if a steel has more carbon, it's stronger, stiffer, and less malleable but will rust more readily. If you've ever had a knife with a high carbon steel blade such as a USMC Kabar or a Boy Scout knife, you know what I mean, they rust as soon as you clean them as they have a very high carbon content.
The older steel is much nicer to weld as well as to work with a hammer and dolly. Less carbon makes it really nice to work. When you see guys working steel with an English wheel, they use a really soft steel called AK or Aluminum Killed (sometimes called Deep Drawn Steel) where it's specially made to be super soft and thus able to be formed into shapes that normal A36 steel would tear or crack. When you form it, it work hardens to retain the shape better.
So, the steel in 75 and newer is more prone to rust given the same exposure. Toyota developed better manufacturing processes around 1989 that results in better coatings and therefore better rust resistance. This is why the newer mini trucks and Land Cruisers built since then have less of a tin worm infection.
This does not mean that the newer steel sucks, it's just not as good, they all rust, the newer ones just a bit faster. That's why I always like older trucks with the goodies from newer trucks swapped on to make a "best of all years".
-Stumbaugh
since they all are going to have some rust, why not look for other desirable features first - like front disk brakes, for example
