Which year is less rusty?
DSRTRDR said:
since they all are going to have some rust, why not look for other desirable features first - like front disk brakes, for example
That's true, but late model trucks also come with something far, far worse than rust where I live - a nasty little devil called Emissions Control Devices and the bigest evil of all called the Emissions Inspection/Inspector. It's bad enough when they are stock, when you have to get a late model V8 swap truck smogged - forget about it. You can get classic car tags, but that does not work in my town with our local gestapo.
-Stumbaugh
-Stumbaugh
I got my de-smogged 2F (prolly '76 or '78) through emissions in an emissions control nazi county (worse than Cali for a '72 truck): Maricopa County in AZ - it was work, granted, but possible
I wouldn't know how hard it is with a V8
1960's definately have there strong points...mine is almost rust-free on the body, and 99% rust free underneath (where it counts). I will agree with Felix..LOCATION LOCATION LOCATION. Other than that, make sure that whatever you buy, whether on Ebay or in a Trader, you get pics and if possible, a test drive to ensure the running gear all works (test the shifting and make sure it engages into 4wd).
Good Luck!
(It also discussed how the mig process was ideal for HSS and said not to try to gas weld it.)
So I have a 78. What will happen if I use gas to patch some of the panels?
Interesting, I was going to suggest it might be because mid-70s is when they ran out of WWII warships to scrap; ie: clean, high quality steel free of the contaminents that scrap always has.
45% of Japan's steel production is, or was a few years ago, scrap-based.
Scrap-based steel is always contaminated to some extent and being an alloy effectively, corrodes more quickly.
The mini truck cabs seem to last much better than the boxes, so probably a better grade was used for them.
Wrought iron has the lowest carbon content of all iron/steel and of course resists rust the best.
Stumbaugh said:
It's not just the fact that it's thinner, rather it's a different kind of steel altogether, it's called HSS (high strength steel – not to be confused with High Speed Steel used in drill bits and taps) by the automotive industry. More carbon and therefore more likely to rust. The idea was to use a thinner and lighter material with the same strength and the thicker and softer steel. I used to have a Toyota Factory Service manual for the dealership body shop's that described this in great detail. It also discussed how the mig process was ideal for HSS and said not to try to gas weld it. In general if a steel has more carbon, it's stronger, stiffer, and less malleable but will rust more readily. If you've ever had a knife with a high carbon steel blade such as a USMC Kabar or a Boy Scout knife, you know what I mean, they rust as soon as you clean them as they have a very high carbon content.
The older steel is much nicer to weld as well as to work with a hammer and dolly. Less carbon makes it really nice to work. When you see guys working steel with an English wheel, they use a really soft steel called AK or Aluminum Killed (sometimes called Deep Drawn Steel) where it's specially made to be super soft and thus able to be formed into shapes that normal A36 steel would tear or crack. When you form it, it work hardens to retain the shape better.
So, the steel in 75 and newer is more prone to rust given the same exposure. Toyota developed better manufacturing processes around 1989 that results in better coatings and therefore better rust resistance. This is why the newer mini trucks and Land Cruisers built since then have less of a tin worm infection.
This does not mean that the newer steel sucks, it's just not as good, they all rust, the newer ones just a bit faster. That's why I always like older trucks with the goodies from newer trucks swapped on to make a "best of all years".
-Stumbaugh
To clarify, when I say gas weld, I mean Oxy-Fuel (Oxy-Acetylene) welding, not MIG (GMAW) as in a wire feeder with shielding gas...
Anyway, it's been a long time since I read that book, but I don't think you'll have any trouble using a oxy-fuel torch to weld it, especially if your handy enough to gas weld sheet metal in the first place! (one of the hardest ways to weld sheet metal if you can do it with out distortion - super old school and very cool btw).
If I recall correctly from reading that book 10 years ago, gas welding was bad for unibody structural integrity (this book was aimed at training autobody techs for all Toyotas, not just Cruisers). The higher carbon content would also be harder to weld. I don't think this would apply to a Cruiser as they have full frames and no unibody. So, if you can gas weld it, I don't you'll have any problems. If you look at the side of the tub around the top of a the b pillar where the hard top sits, as well as the side of the cowl, there are a few gas welds. I don't think you'll have any trouble.
-Stumbaugh
I have heard that it's not true that recycled steel is any worse than new steel made from ore, but it has to be quality process to either make good steel in the first place or to recycle it - but I am no metalurgist and that is just what I have heard. Certainly, what you say is true, there is a lot of crappy steel out there, but I am not sure if it's from recycling or low quality steel mills. My bet is the carbon content of recycled steel is higher because it has lots of used machinery tossed in and that's what causes it to rust more.
I do know that it's interesting to work on different makes of cars and note how differntly it welds as well as how differently it responds to hammer work. Old German cars are a pain to weld compared to old American cars, they are harder to work with a hammer and dolly as well. Needless to say, they also love to rust really badly.
As far as the cab's of mini's holding up better than the beds, it's because Toyota made the Cabs in Japan along with the rest of the truck and the beds were installed in Long Beach Ca - this was done to get around tariffs as the trucks were brought in as unfinished assemblies at a lower tax rate. I had a new truck from that era and my friend worked at the body shop at the Toyota dealer ship - could be heresay, but that was the story at the time. The dealer used to list Japanese beds and USA beds when they sold replacements. The Japanese versions had tie down hooks on the outside and double tail gate latches where the USA beds had a single handle and no outside hooks along the top of the bed.
