Which tires do you recommend?
I have a 97 anniversary edition. It is bone stock. Currently I have LTX Michelins 265 on it. I would like more aggressive tires in a somewhat larger size. This is my daily driver and our family recreation vehicle. Suggestions? Thank you in advance.
oh good, I get to be the first person to say "use the search function!" no I'm just kidding, I wont do that, but this topic is typically beat to death. I have the exact same rig and I would recommend Goodyear Duratrac 285/75r16 D rated. Expensive but super quite, very durable and aggressive. they are a larger tire you will be undergeared (less power, incorrect speedo, etc) but I found that my highway mileage actually jumped up a notch without a very noticeable hit in driveabilty. You can also get them in the stock(ish) 265/75r16 D rated I think. The pros of the duratrac are:
great snow traction
great all terrain traction
good load rating
good wear rating (assuming you rotate religiously)
quite like a street tire (mostly)
Cons are:
expensive
tend to exacerbate freeway wandering
the rumor is the sidewall is week, but I've seen no evidence of it.
I have these tires on very tired very stock suspension for about 8 months before I lifted and they don't rub ANYWHERE
I'm running yokohama geolander ats' s, they are smooth and quiet. Wear pattern seems great I have clocked about 8k miles on them and they still look new. Driven in hard pact dirt loose rocks light mud and wet payment tires never missed a beat.
Downfall is the sidewalls aren't they strongest, I lost a tire to a sharp rock one time, then again I wasn't aired down and they were hot from running on the freeway...
BTW they are 285/75r16 On a 2.5 lift
I have a 97 with similar requirements, so I'll add my two cents. I ended up going with 285/75-16 Falken Wild Peaks. I've got about 11k miles on them. Awesome street tires (quiet, ride great, etc). Only non-street use is snow and light trail use. So far so good. They seem to get good reviews online.
I ran them with stock suspension and also about 3" of lift and they fit/look fine.
Unanimously the most popular size that fits your description is going to be the 285/75/16 and all the smart guys are running the Yokohama Geolander At's.
Another vote for Duratrac's. I have about 10k miles on mine and have been very happy with them.
The "done to death" part of the "what tire" question, is "What is the biggest tire that fits a stock land cruiser?" I think 265/75R16 (31") was stock. 285/75R16 (33") fits stock wheels and (20 year old) stock suspensions without rubbing. 305/75R16 *may* fit after trimming the rear mudflaps and moving the bump stops down, but depends on who you ask. They may need a lift to fit. 315/75R16 (35") are likely to need a lift to fit. Depending on who you ask, they 35" need between 2.5" lift (my brother had 35s on an 80-series and 2.5" lift") and 5" lift.
The piece for which there is less of an answer from others, is which *model* of tire to buy. It sounds like you have a handle on the choices and trade offs. Cost, handling, noise, traction on various surfaces. My last tires were Interco (Super Swamper) TRXUS. They were supposed to be a very aggressive looking tire, but have enough siping (small rain grooves) to stay quiet and do well in rain and ice. I found the TRXUS to be as loud as my previous BF Goodrich Mud Terrains.
My recently purchased Land Cruiser had Falken WildPeak all terrain tires on it (stock 265s), and I'll run those to see how I like them. First impressions are excellent. 20140824_131712.webp 20140824_131748.webp
I guess you'd be wanting an AT tire as a step up from your street tires. I went with Firestone Destination AT's. They pull me through sand easily and show great treadwear in the nearly two years I've had them. They're consistently rated #1 or #2 on Tirerack's owners survey. They're quiet too.
I wound up with Falken Rocky Mountains (Wild Peaks but made for Discount tire only) in 285/75/16 they fill out the fender wells nice and did really well on a partial run up Rocky Gap trail (youtube it, it's awesome). Also on the highway they are very quiet. Review very well and only $135 per tire from Discount before labor. (work a deal, they will probably get you close to $150 per tire out the door if you try)
Wishin' we had a Discount tire in Hawaii...great job on a great purchase!
I'll second the Yokohama Geolander AT-S. I've had two sets on my LX450, stock springs and shocks, 285/75/16 on stock wheels. The first set I got about 80-90K miles on them. They wore great, and I was able to keep two as spares after all that mileage. That was with about 5-7k off pavement driving (no hardcore stuff, but lots of beach driving, forest roads, and mild trails.)
They have a nice quiet ride, are about $30-60 a tire cheaper than michelins, goodyears, bridgestones, and bfgs. They are great in rain, snow, soft sand, and light mud. You can air them up when towing if needed. They are soft enough compound to give good wet weather traction, but hard enough to wear well. With the solid front axle, they take forever to wear (as long as you rotate them). Ive put about 20-25k on my second set in the last year, and have had 0 issues. I run mine about 36psi all the time.
I'll be the first to say the BFG KM2. It's not my daily driver but I like the noise. The traction is great and wear is minimal after 8k miles roughly. I would buy em again assuming I can afford them Haha.
Otherwise, I have the Terra Grapplers on my tundra and like them more than the KOs I had previously
I bought a brand new set of BFG A/T for my Tahoe (sold) and they chunked off big pieces of lug out here in the Nevada desert. They weren't that solid in snow either.
They were Load Range "E" if that makes a difference.
I second the vote for BFG KM2, especially in the 37" size.
What oil you are currently running is pivotol in choosing tires?
Are you using Synthetic or Dino, Weight, and Brand?
