where the hell does this go?
Took this off the underside when I was Waxoyling the truck 2 years ago. Where the heck does it go? A photo would be great.
I would just start checking frame rails...
Seriously, could someone snap a cell phone pic of the underside of the front end by the steering stabilizer.
That's not at all what my steering stabilizer looks like. It's not a 'pan' of any sort. Must be a heat shield.
I believe it's a heat shield as well. I took mine off when I was degreasing the underside of my 80 a few years ago. Then decided to paint it up real pretty. It's still sitting in my garage on my work bench. Haha
It's a cat heat shield.
Do/did you have running boards? I had running boards on my 450. When I removed them that piece was between the running board & the cats to keep the heat off the running board.
It's a heat shield for the cat.
As mentioned above, it's a Cat heat shield to decrease heating of the right side rocker panel, it mounts to the inside of the rocker panel and can only go on one way. Once you're under the truck and hold the shield up to the bolt holes it should become apparent how it mounts.
FWIW I added a layer of Hushmat hoodliner to my shield (facing the cats) to further decrease heat as well as vibration of the shield, also plan to add a high heat fiber washer between the shield and the rocker panel to decrease conduction of heat from the shield to the rocker panel. Previously I used an infrared thermometer to check bare floor temps (carpet removed) with and without the shield and found that the shield does decrease the heat load on the rocker panel and subsequently decreased conduction of heat to the floor.
