I saw that you are running a 2F shroud, I cant speak to the 3F engine, but I run a 40 with a 2F that was heating up badly, I replaced the entire system, rad, water pump, thermostat, hoses, valve job because it blew a head gasket, block flush, temp sender, yes it needed all that, yes it seemed really hot under the hood before all the work, the one addition I made was an 8 blade fan, I spoke to Mark A., the 8 blade will fit perfectly in the tapered 2F shroud, I dont know if the bolt pattern is the same from 2F to 3F water pumps, but if it will fit I recommend it, I can feel the air blowing out of the louvers on the hood, and now Death Valley, I can idle all day, So Cal traffic, no problem, the one issue I have not replaced is the Temp gauge, even after all the work the gauge red lined! I installed an after market and problem solved. Another trick to see what the water temp really is, get one of those Air Conditioning thermometers, long probe with the small dial indicator, stick it ibetween the fins on your radiator, run the truck, you can see it heat up, the thermostat will open, temp will drop, when you shut it down it will heat up to actual water temp, you can double check your dash guage with it as well. Sorry for the long post, but this one really had me stumped and cost me some bucks, hope this helps a bit.
