When the radiator ain't enough?
38.0111,-109.9181
Website
www.alamosa.fm
My 3FJ40 gets hot here in PHX. My new 40 series 4 core may not be up to cooling that hot 3F-E? Are electric fans REALLY that much more cooling?
Can I put an electric PUSH fan in front? Can I put a fan in the hood? What'ya suggest for additional cooling? other than moving back to Colorado.
Pusher yes
I put a pusher fan in front on my 40 w/Chevy V8. Some hook mine up to a switch and use it when needed. Others hook them up to a temp gauge to go on automatic. It works well. You can also try water wetter, but becareful if you go back to winter area it can freeze.
Scott, do you have a good proper-fitting shroud? The cooling capacity of any radiator is limited my the amount of air moving through it. I do not mean to oversimplify, so please don't be offended. I have seen a lot of SBC conversions that had no shroud. It is absolutely essential.
Ed
i wouldn't rely on hooking your cooling system up to a switch that you, yourself would have to turn on .... not to reliable....
a shroud will probably help... a taurus fan is a good idea, better cooling and adds the hp that a mech. fan takes away.
Electric pusher fan; in my truck, PO had installed one already since it has no fan shroud (neither 2F nor 1F shroudd will fit the fan I currently have - I will booty fab one when I get around to it). Since I have a 2F, I usually only need it in the summer here in AZ. In my case, it is switchable from the dash via a lighted switch so I don't forget to turn it off (it also makes a whining sound, hard to ignore when the truck is off, actually).
It might be possible to wire it with a thermostat...............
JEG's has a barely over 2 inch slim fan on page 64 of their catalog that should fit within the confines of a 40. wantatlc just installed one in his rig (V8 conversion), he is in southern CA. Search for his thread or contact him directly to see how he likes it.
HTH
It looks like you already have a new radiator, but aluminum ones sure can help.
I do. It's the original 2F fan shroud on which I had to do some slight trimming due to the 3F-E water pump offset. I had to trim off the lowest smallest corner of the 2F shroud. Perfect? maybe not, but definetely better than without the shroud.
As far as the pusher fan goes, what fan does everyone use? Is it mounted OUTSIDE the grill?
there are many models available, suit your taste. I'd search Summit, JC Whitney, Jeg's. They all usually mount to the radiator with adjustable mounting strips and some 4 bolts. Depending on depth, you may or may not clear the grille (see above post regarding slim design). PO in my case had removed the grille due to interference with the pusher fan motor. I now have a custom grille (that I made from hardware store material) that is held by the Bezel.
If a replacement fan is an option a Taurus electric fan would be a good upgrade, I'm not sure what the cfm is on your currnent set-up is but I do now that the Taurus electric fan will pull about 4000cfm. Search here and on pirate4x4.com for lots of info.
I live in Tucson and my 83 FJ60 would overheat when I was idling in traffic so I got a slim pusher fan from PepBoys and installed it in front of the radiator. I also got a thermostat to go with it, but the wiring was a bit complicated for me, so I just wired the fan to a switch on the dash and spliced the juice in from the wire that goes to the radio. This way it always shuts off when the key is off so I wont accidentally leave it running and run down my battery. Now the temp gage may go up to 75 or 80% when I'm sitting in traffic in the middle of summer. So the add on pusher fan definately keeps me out of the danger zone.
HTH
Matt
I had some cooling issues (before I realized that my radiator was not working at capacity due to a 1/3 blockage of the core). I used an oil cooler and I believe it helped, since it resolved the problem. I didn't take any temp measurements before or after, but you may want to considerit. I used a "sandwich" type, which fits between the block and the filter.
Good luck.
The issue with the big primary fan being electric is that I only run a stock 1978 2F alternator (45 amp). My understanding is those fans can draw upwards of 20 amps, plus the additional electric load from the 3F-E conversion may be pushing the bounds of the electrical system?
Upgrading the alternator means getting rid of the ammeter in the dash which I like. I've thought also about running an additional alternator though...
The 2F has a stock cooler as well, but it does not have much airflow to it. In my oil cooler application, the cooler was a small heat exchanger that I was mounted in front of the radiator (size was not large - maybe 4" by 8" if I remember right).
Another added benefit is that the oil capacity is increased by about a little more than a quart.
I am a believer in the usefulness of Auxillary fans in certain situations... just read this as it offers some great info and photos on putting one (and which one) into an FJ :)
https://forum.ih8mud.com/showthread.php?t=81512
Page 2 shows the fan, install, results, etc. Page 1 covers much of this topic. PLUS: I didn't have to remove my grill as I found a nice thin fan.
If you are overheating a stock 3F and you have a brand new radiator you have other issues than cooling.
You sure the motor is running correctly?
I don't believe I'm overheating yet, I am plugged into the 40 series temp guage and still need to calibrate. Also, the 3F-E is with a smaller 40 series radiator vs. the larger capacity 62/80 radiator. It just feels hot, you know after driving a 2F for so many years it just feels a lot hotter in there; knowing the 3F-E is a hotter running engine.
Have you checked the fan clutch to see if it is working? And is the 3F fan interchangeable with the 2F fan? The 2F clutch is 7 blade and with a shroud, should move a lot of air.
I would also install an aftermarket temp gauge.
GL
Ed
