I prefer removing the radiator cap and driving a new truck under it......![]()
Bang.
if you get stuck on I 70, I know a guy that can help you....This isn't a "rabbit hole". It's like the title says, when it rains, it pours.
In any case, I'm glad I discovered these things in my driveway rather than somewhere in Kansas on I70.
Or two.......if you get stuck on I 70, I know a guy that can help you....
shoe fitsAnd they look at me like I'm rain man.
Onur is the man, no doubt.Onur got me new plugs for my fuel injectors when i did my head gasket they were a little trick to install but new plugs are so nice. I really should replace a bunch of them suck as the distributer and alt one you just broke.
Is the alt that it is stuck in something that you want or will it be trashed?
Because if you dont care about it once i get the new plug and new alt i would just start cracking apart the plug and removing the wires on at a time. You should be able to do it with out damaging the wires or metal pieces on the end of each wire. You might not damage the alt side of it or it might get damaged. If you care about it then i am sure someone will tell you how to remove it properly. Then just install the new OEM plug and new Alt.
Thanks guys. I appreciate it.Or two.......
