Wheel Spacers
https://system.na2.netsuite.com/cor...7654&c=407909&h=d9bfd331cf327ecdd54e&_xt=.pdf
Shows the tapered lug nut and taper in the spacer. If you buy a spacer that is just straight cut and has flat nuts to save cost than yes you will need to do the 3 nut method.
I am correct in the method? Use three conical nuts to center, then use non-conical nuts to lock into place, then remove the three conical and replace with non-conical??? So by the end, all six nuts are non-conical?
The spidertrax spacers come with conical nuts that attach the spacer to the hub. This will center the spacer correctly on the hub. The 3 nut thing that has been mentioned is referring to the stock nuts attaching the wheel if I'm not mistaken. However, that depends on the style of wheel you have. If you have the early style OEM aluminum wheels with the conical lug nuts (wheels have rubber sleeve in the lug hole) then you want to get the wheel centered (lug centric) by tightening 3 lugs in a triangle pattern.
If you have the later style OEM wheels with the shouldered lug nuts then I don't believe this method is necessary as the lug nut bore and shoulder will center the wheel on the spacer studs properly.
At least that's what I've heard described. I've used these spacers on both types of wheels and used this method. Never had an issue with either one. Pro-tip, use red Loctite on the nuts attaching the spacer to the stock studs.
Sorry - had a brain fart. Yes, the nuts that come with the spacers are tapered and work fine - just follow the instructions. What I was referring to was actually when I mount tires I use the three nut method.
