What’s it worth?
monroe ga
Well I finally got more information this morning... insurance has totaled the Fj40 and the customer took to pay off and bought it back. Now the real question is what is this thing worth! Body mounts are ok but I noticed yesterday that the bell housing is cracked.. body definitely has damaged on rear at the seams.. paint is chipped and definitely a lot of work..
Can see the rear sill has been replaced which probably means it was rusted. Not sure if the B pillar does not look original. Spot welds were filled over the wheel wells. No being a original rust free tub the quality of the previous work comes into the value. Is it free of bondo? Original rust free is worth a lot more then one full of bondo. Nice paint is now worthless since by the time it repaired will be need to be painted again. Since it's been totalled it will be registered on a web site. Clean frame with VIN plaques is the only way to cover that up. I would be sure any frame you get is not off of another totalled cruiser.
If you offered it for sale as is for $5k, I bet it would sell fairly quick.
The Jeep top could be a possible indicator someone cut other corners during the build. Did they slop bondo on a swiss cheese tub? Most do.
Not a lot unfortunately. As others have said, there is a whole lot of wrong happening.
The frame, body, bondo. The shiny paint means nothing.
If you want it for parts, thats one thing you could use this for and get some decent parts from. Personally, $1000-$1,500 because of all the unknowns. That front axle could be tweaked and engine messed up as well. :meh: The rust coming through at seams just makes me wonder whats underneath.
I had a wrecked 55 and ended up parting as there was just more and more messed up the more I dug into it.
It looks like it rolled in a field of pillows -- hard to tell but how does a truck get so completely mangled without dirt, scratches, broken glass etc?
Crazy.....
Hit a tree in the front at the end of the left frame rail. Tree didn't move, left frame crinkled and right side moved forward causing all the damage to anything attached to both frame rails.
Parts car with better than average paint. Too bad, as it looks like someone put some time and money into it. Could it be fixed? Of course, but it probably isnt worth it.
It took a good lick right in the front L frame rail. Lots of stuff attach to that frame rail :)
I also believe parting it out would get the most. When selling used parts it is hard to narrow down a price. Doors, hood, windshield frame and front bib could get 1500 or more depending.
