- Thread starter
- #2,921
transmission flush fixed the problem! i was expecting to have to spend 5K on a new tranny, so $300 for a flush isn't too shabby.
Replaced the steering rack bushings on the Runner. Much better!
I got the Energy Suspension poly kit from Toytec. It wasn't hard at all. Took about 2 1/2 hours including gathering the tools and getting set up. There is a good write up on Mud with some good tips. The center bolt is a little difficult to get to but not too bad. The new bushings go in pretty easy. Then it is just a matter of lining everything back up which took a little effort.
Sent from my iPhone using IH8MUD
Did you ever do anything with your brakes?
There is a lot of talk out there about the front brakes, but not much about the rears. It seems to me, at least on mine that the rear is more of a problem in that after time they don't stay adjusted. I think this is what ends up causing any problems with the front because they end up doing all of the braking. I plan to totally rebuild the rears and then do something with the front. I am still debating on whether or not to do the Tundra upgrade. I might just go with new pads and rotors first and see how the rotors hold up with the new parts in the back. I have adjusted the rear and it made a big difference.
trust me on this bigger is always better when it comes to brakestrust me on this bigger is always better when it comes to brakes
larger bore master cylinder as well if you can`t fill them bigger calipers they aren`t gona b doing there job to the fullest![]()
