What tire size with soa
Ok so I am doing a spring over w/ shackle reversal and have read tons of the info. I have a 72 40 with a 350. My question is what tire size can I, and do I need to run with a soa. I would like to run 35's since I hope to drive it on the street as well as off road. I want the tires to look good as well as not smash the fenders. I see people running 37's and 38's but that seems huge to me. Thanks for your input.
If you use one of the shackle reversal brackets with a SOA you may end up with quite a bit of lift, 35's may look a little small. I think the shackle reversal bracket gives you around 2.5" of lift over a standard SOA. The rubber overdrive with 35's is pretty nice on the road but plays heck on your crawl ability. With the SR flush with the frame 35's would look pretty good.
35" is about the bigest you will want to run on the street but than again you dont need a SOA to drive on the street.
With a SOA 36-38" is a good range but you will need to upgarde your birfs and axles as well especialy with a V8.
Go with 38's other wise it will look goofy and you will alway wish you had gone bigger. Save your self the money and do it right the first time.
Also do like 71-CRUISER said and beef up the front axel. You may also wnat to chang out your gears too.
lots of opinions here, I went with 35 mtr's on mine, just bought em, I can send you a pic when they are installed so you can see what they look like. I have a SOA stock 40 springs with some long add a leafs on each corner. With my setup, 37's would definetly rub, I have 33's now and they are too small. I thought about 37's but that would knock my crawl ratio way down too much so decided on the 35's. Also, many tires are larger or smaller depending on their brand, I think my 33's are really 31/32's as they are BFG which typically run smaller than goodyear.
Noah
Hi All:
Two of the guys in our local 'Cruiser club have SOA FJ40s; one is running radial 35X12.5 Cooper mud tires, the other guy has 36X12.5 radial Super Swamper TSLs.
Both seem happy with their tire choices.
An observation: most radial tires run a bit smaller in diameter than the size indicates, thus 35 inch Cooper radials are probably closer to 34 inch diameter in realty, while Super Swampers are know for runing close to the stated size. Thus a set of 36 inch 'Swampers is probably pretty close in size to a radial 37 inch tire from other manufacturers!
The realty of the situation is that 35 inch tires will generally behave better for town and highway driving while the 36 and bigger tires will be better off-road.
It is a lot of $$ to spend; I'd advise against brash moves! ;-)
Regards,
Alan
Seattle
My buddy had 35s, I had 38s, both soa, his looked like a rollerskate, mine fit. Go as big as you can afford cause if the tires are too small you'll be spending money on tires twice.
