What rims?
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
I'm trying to locate some rims. And I have no clue as to what backspacing I need.
It's on a 76 SOA. Stock drivetrain, 4w Disk, Saginaw.
Currently running Dueler A/T 33 inch tires on 15 inch rims.
What I'm planning on running. 37 in BFG Krawlers custom cut treads. http://www.rockcrawler.com/techreports/bfg_krawler/preview/index.asp
1. Where could I find a good deal on some rims?
2. What should I have as far as backspacing and rim width?
3. I do moderate wheeling but drive my vehicle on the highway and drive it to and from club outings. Am I crazy to think these tires are worth the effort?
I know if I go with these tires I'm going to have to change gearing which is an even more expense. I probably going to have to upgrade the birfs. It just seems like a lot of effort to make the 37's work correctly.
I'm getting 7 brand new tonight for $100 a piece. 4 have already been cut to the same pattern as the normal ones and 3 are the uncut. I'm crazy to pass up on a deal on these.
Maybe I should just resell them and pay for a nice set of 35's that will fit on my current rims. They are selling for 370 each on the web. I would think I could get at least 200 for them. Everyone in my club thinks I'd be crazy to sell them.
What do you guys think?
Would I have to cut more bodywork to make them fit?
3- they are not going wear for s*** on the highway, as they are not designed for that type of use....good thing you are getting seven. :)
If you do decide to get wheels for them, I would have some custom steelies with a 3" or 2.5" BS made. I know pleanty of people running a 2.5" and 2" BS on the road...TJ flares in the rear...
Me-
I would turn them and try and offset the cost of 30 spline Longs and gears...as it seems that the cash infusion needed to make the truck work with those tires is outside your budget...
This is an exspensive endeavor to do correctly, there are no two ways about it.
Good luck!
-Steve
Run the 37's for Trail Use Only
Everybody agrees that these will not wear well for daily driving.
I'd say keep 5 of the 7 and resell 2 to offset the cost of the rims (You'll need 3.5" backspacing bare min [really 3" to be comfortable] - but agree that 2.5" or 2" is best) - You will need even more if you go with a true double beadlock. Don't go 35's - you'll always want bigger and you'll kick yourself when you get tired of the 35's (trust me on this). Keep your 33's for daily driving and switch out for the 37's for bigger rides like GSMTR and anthing else you do. I forget what locker you're running in the front, but if it's open, detroit or ARB you can avoid serious birfield breakage and prep. and switch to mini-truck birfields until you can afford Newfields or Longfields. Ask Allan H. to send you the e-mail I sent him on how to swap in the mini birfs - pretty straightforward but you have to have it prepped before, not on the trail :flipoff2: Note: I never broke a single birf using 33 BFG's, 35 x 16 Boggers or 37 GY MTRs - then when I went to 38.5 x 14.5 TSL/SRs and started breaking them and many other things like candy. I think you might be close to that with the 37's if they're as sticky as they say.
I just got a set of the 30 spline longs for the Christmas sale - now I want bigger tires :D
IF YOU DO SELL THEM - I am going to lobby Allan H. to get them so be ready to give him a deal. :D
Thanks Sputnick. Yeah Alan is first in line.
hey troll i run 2.5 backspacing and they are much beter looking and fit better than 3.5 i had earlier before soa. i just went to discount tire got them new 36 bucks a peice. they usually beat anybody just tell them you found them some where else cheaper
Good new I bought the tires.
Bad news. I just don't have the money to buy everything else to make it right. So I'm going to sell tires.
Good new I got a sweet tire sipper.
