- Joined
- Feb 8, 2004
- Threads
- 294
- Messages
- 5,761
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
removed my headlight rock guards and put on my new early Toyota turn signals
Took the top off!!View attachment 940855
Scraped off old ****ty bedliner from incise the tub....So i can start sandblasting and welding
Made some progress building a spare 2F motor.
Looks great Cleg...question...is this hose bracket here on backwards? I will be putting mine back together soon and I thought it went on the other way (opening of loops towards the rear). Thanks,
SkipView attachment 941315
I recommend using aircraft grade paint stripper, its expensive but it melts everything. Let the stripper do its job, leave it on there for a good 45min to an hour. Then find a chipped or broker wood chisel and sharpen it and make it nice and flat. 3/4 inch works well, also having a larger sharp floor scraper maybe 3 inches. Wire wheel does nothing, and sand blasting will take much longer with bedliner... Good luck@aircrew - this is in my future, as well. Any tips? What did you use the break the bedliner loose?
10-4 Cleg...I will be there soon enough. That engine looks great and your 40 is super nice! Thanks for the reply, wrench on!Skip,
The engine was complete when I picked it up and appeared to be remarkably unmolested. I thought I took a lot of pictures for reference but the position of the clamp is not visible. It is installed in the picture above the same way it came off, with the water line laying tight against the side of the timing cover. You can see a little of the hose in this shot below but the orange strap is hiding the bracket.View attachment 941380
You're not bragging here are you? Lol. That is a beautiful rig! Keep bragging.Took the top off!!View attachment 940855
