What have you done to your Land Cruiser this week?
Finally made some time and mounted 4 shiny new Bilstiens onto my filthy 40 then went for a cruise around town. Damn, what a difference they make! Rides much smoother over bumps and body roll around corners has drastically improved. Can't wait to get them off road!
What were you running before?
That said, just about anything would be better than the tired Rancho 5000s that have been there a couple decades.
Replaced the rear corners.
Awesome shock… :beer: :beer: :beer:
The worn out shocks I replaced were the ones that came with my HFS springs, not sure what brand CCOT uses. Been on the 40 since 2004.
Ironically I had Rancho 5000s for several years before that! 👍
Wrapped us this metal tech cage for a buddy’s 81’ fj40 with an aqualu tub.
Looks great. Hopefully someone grabbed that right angle magnet stuck to the rear carrier before he hit the road, that would suck to have come at you on the highway! Both those 40's are bitchin!
- OEM CALL OUT # 82612 , INSULATOR FUSE BLOCK TERMINAL . PART # 82612-20020
- is officially ALIVE once again , and light-years ahead of the original , via my over-engineering mind-set approach ,
- 3-M sheet insulator material is the best possible modern materials , keeping the purist vintage aspects of the originals ..
- comes with 2 #4 mark head made in japan mounting bolts too gold plated double SEMS
Ruby went for her first real outing... the HAC seems to be working great at nearly 9,000 foot Marble Pass Oregon. Got her good and stuck in a mud hole so the winch is also fully checked out!View attachment 3062056
Where's the pic of checking the winch out !!!!
The sandals are the cherry on top.
Finally circled back to the broken air rail. Appears to be the first time it’s been disconnected in 41 years. One of the air injector nozzles broke off in the captive nut on the air rail. The steel pipe was also badly bent. I had to choose what to salvage so I went with the captive nut because the pipe was thrashed. Cut off the pipe, drilled out and tapped the nut captive nut, ordered a $1M replacement used air injector nozzle from SOR, purchased some 8mm OD / 6mm ID steel tube, bent that to shape, cut to size, aligned, welded to the air rail (forgot to turn on the gas so the initial weld was garbage but no one other than y’all will see it), installed the captive nut, drilled out a nut to use as the new pipe flare, welded that to the pipe, ground it to size, re-aligned the pipe because the welding heat pulled on it. Mocked up and good to go. Now for cleaning and off to get it cadmium plated.
With my sand car finally reassembled and running, i spent the day resetting the garage space for some upcoming cruiser tinkering. First time I’ve parked a landcriser under a roof i owned. I’m pretty excited to be able to tinker on flat concrete and with proper overhead lighting. I did some test fitting of an auxiliary tank that i will be installing for supplemental fuel storage. I hope to take my ‘69 on a roadtrip before winter arrives.
The Air Injection rail nuts are not captured, you should replace them all due to age and time crusty factor there going on
Below are Japan Spec. Injection rail service parts , the red brass / bronze sleeves and the nuts them selfs ….
You have it use a sharp face nipper like the NIPPEX brand and actually cut off the side face cleanly then u can get them off
Out with the old in with the TEq new , it’s a solid MAI system for you …
Man I need you on speed dial. Could have saved myself a lot time and work.
Drove to town and put $40 in the gas tank.
