View attachment 2021623View attachment 2021625
Clearanced the bell to stuff the later birfs
Along with the disc conversion.
In!
I had to do the same thing on my '76.
When I rebuilt my front axle I went with Longfield mini truck birfs (shorter) so I could upgrade from Warn to Aisin hubs.
Here's a few pics of the difference:
How do you get the case that clean?Continued cleaning and prepping the drum parking brake split transfer case to go behind the H41 for my '71 FJ40 build. Today I tackled the transfer case vent. Thought I'd try pulling the pressed in stock vent so I looked at assembling a temporary tool. I pried off the sheet metal vent cap and noticed the hole looked like it could be easily tapped for a 6mm bolt, a few minutes later and it was done. I picked through my stash of non-Toyota metric bolts and found a longer one that I could thread all of the way through. I then picked through the assorted spacers and plate washers and found a spacer and washer that would give me a large surface area to pry against. Threaded everything together and used a flat pry bar to pop it out. A trip to the local hardware store for an elbow, and finally found something that would work. The PEX elbow has barb-type ribs on it, but I had to file down the OD of the outermost rib (inside the case) to get it to just press through the smaller ID inside the case. I smeared on a little Three Bond gasket maker around the perimeter at the outside of the case before pushing it in. I may have to go back and figure out how to make it fit a little more snug, maybe a small O-ring. The hardware store also had a thin wall brass tube the the same OD as the stock vent (15/32") and about the same ID as the ribs on the elbow, should make a nice, snug fit.
Now I just have to find the proper diameter hose and it'll be ready for when I get to installing the drivetrain later this year (I hope).
That's the inside of the case, the other side - not so clean. Still working on cleaning the outside.How do you get the case that clean?
Drove it. Put 3K miles on it over several days. Went from Olympia, WA through British Columbia, cut across the Yukon Territory, crossed into Alaska, headed for Eagle River, AK and then on down to the Kenai Peninsula. Changed the spark plugs, fuel pump and fixed the parking brake along the way.
The FJ40 looks right at home up there!Drove it. Put 3K miles on it over several days. Went from Olympia, WA through British Columbia, cut across the Yukon Territory, crossed into Alaska, headed for Eagle River, AK and then on down to the Kenai Peninsula. Changed the spark plugs, fuel pump and fixed the parking brake along the way.
Thats Awesome i would live to read a whole thread on that trip! hint hintDrove it. Put 3K miles on it over several days. Went from Olympia, WA through British Columbia, cut across the Yukon Territory, crossed into Alaska, headed for Eagle River, AK and then on down to the Kenai Peninsula. Changed the spark plugs, fuel pump and fixed the parking brake along the way.
