You'll like it, but not during the installation.And thanks for the reminder, I just ordered my kit today.
It is a modular design with standard 1x2 80/20. This makes for a very versatile platform. AFAIK it’s also the lowest option so it saves a couple inches of clearance. The built in valance is great too. I’m pleased.Very nice! Are you saying that because you can mount the tent to the cross bars, and then put it on the roof and bolt the cross bars into the Prinsu rails/mounts? (I don't have either Prinsu or RTT, just have been reading up). Or for some other reason?
I’m paranoid that it’s going to leak so I’m going to try to shoot a nutsert in the holes so I can get a bolt In.
They will absolutely leak.
Installed a full length Toyota rack:
So much room for activities now!
This should have been a one banana job but two of the clips for the bolts fell to their death somewhere in my headliner. I’m paranoid that it’s going to leak so I’m going to try to shoot a nutsert in the holes so I can get a bolt In.
Learning as I go!
Are those OEM rails or did you get the ones all over ebay? Did you read the long thread on here about the perils of removing the factory rails?
Yup, I know.
Just finished this upgrade a few minutes ago.
For anybody considering this, a few tips:
* The Slee directions make it seem a little easier than it really is, but it's not bad. This is the second time I've installed this tray. It's much easier if you remove the front wheel, you have a lot more room to pull down the inner fender liner.
* Drilling the hole for the 4th bolt seems a little overkill, but I did it anyway. Seems like 3 3/8" bolts would be sufficient to hold it down.
* Get stainless bolts for the tray.
* The toughest part of the job is holding the bolts from above while you try to wrench the nyloc nuts from below. A second person makes this much easier, just to hold the wrench from above.
* That Group 31 battery is one heavy SOB. Put a blanket on the rad support, hoist the battery up and set it there while you re-position and stand on a raised platform to set the battery down into the tray.
Time for a![]()
Has anyone swapped connections to have the starting battery be the smaller one on the passenger side? I did this on the 100 and it worked well as the main cable comes from the center back of the motor and can easily be swung to the other side. Then just jumper over to the main fuse block with 2ga. Haven't researched feasibility with the 200. Hoping the group 35 can keep the hotel loads running overnight even in the summer.
Learning as I go!
