I would suggest carefully flexing it out in a controlled environment to look for interference. Good chance you’ll be getting significant contact.. some of which could do damage.
Yes I plan on it when I can find somewhere toI would suggest carefully flexing it out in a controlled environment to look for interference. Good chance you’ll be getting significant contact.. some of which could do damage.
Yeah, I'm going 0 on mine.
Thank you for posting, was about to say I think there is a whole thread of 34/35inch tires with zero offset wheels, and how they still stuff in the fenders with no issue. I think my 33s will be okay.For what it’s worth I’m on 2” lift and 35s with “0” offset.
I haven’t torn a fender off yet. Rear mud flap yes but I backed over it.
Sure they rub. But it’s never been detrimental. My body mount is chopped/ plated and front fenders trimmed on the inside. Otherwise not much issue.
Thank you for posting, was about to say I think there is a whole thread of 34/35inch tires with zero offset wheels, and how they still stuff in the fenders with no issue. I think my 33s will be okay.![]()
I almost wish I would have went 285/75/17 but I think these still look big enoughI had the same tire size as you do before I went to 35s. (285/70-17) zero issues on mine.
So you go in eyes wide open...
This is what things can look like and this isn't fully stuffed. Stuffing square (both tires compressed) is different than stuffing one articulated tire. My setup is not +0 offset and I have wider tires. The maths are that your tread is a full 20mm further out than mine. View attachment 4115871
You're on tender stock springs and likelihood of full compression is higher than someone that is on firmer aftermarket suspension that essentially limits compression. The body also moves relative to the frame.
All to say YMMV and if you do any real aggressive driving combined with off-road. Watch out for those shiny fenders.
Got a pic?I ordered and installed some black window trims from Garage Alpha Off-road
2008-2020 Lexus LX570 Black Window Trim
If you're looking to knock some chrome off your LX570 - do it right with full on replacement parts. In order to make install a breeze, we are now importing and stocking the JDM/AUS Toyota Land Cruiser BLACK Window Trim. This is a direct bolt on for your 2008-2020 Lexus LX. Simply roll down the...garagealphaoffroad.com
Thought from the description they are OEM... doesn't look or feel very OEM...hmm..
Anyone has any experience with these?
The trim has that cheap rubbery look..one had some damage too.Got a pic?
Dang, from afar it looks decent. Also, your heritage wheels on an LX, damn. I’ve never seen that combo before I don’t thinkThe trim has that cheap rubbery look..one had some damage too.
I don’t have a 2015 or older model to compare it to.
Should have just ordered this from Amayama.
Ya doesn't look too bad from far away. Not sure about durability long term. I need to compare it with an actual OEM part to see if this was a knock off.Dang, from afar it looks decent. Also, your heritage wheels on an LX, damn. I’ve never seen that combo before I don’t think
Is that pic with your 37s and body lift?So you go in eyes wide open...
