What have you done to your 200 Series this week?
Is that pic with your 37s and body lift?
I'm thinking this pic of mine is probably a rear bottom out. Rear has 1.25" spacers, 35x12.5r17 ko2 and rock warriors (10mm wider offset). That puts me around 18mm offset, right?View attachment 4116125
In comparison when flexed, tire goes up a bit higher, but angles in.
Front is a little wider with the tundra parts, but still clears.
Great looking bumper and nice action shots. Too much much fun with your purpose built namesake lightweight desert cruiser. When is the supercharger going on?
To your question, pic was on 35x12.5R20s and no body lift Toyo AT3s. Yes, you're effectively on +18s. Whereas I'm on +32 with almost the same overall tire size . This is where KO2s running slightly smaller helps compared to other ATs.
@ChattTNUJ200 is +0 with a shorter, narrower tire, pushing the outer sidewall out another 12mm (1/2)" out relative to yours. But on a Falken AT4W that has even more aggressive dimensions than both our tires, and sidelugs probably 14 - 18mm further outboard than your setup.
The geometry is actually worse on the passenger size. This is with AHC dumped and parked, but it does travel deeper in dynamic situations from witness marks of lugs getting chewed up by the fender lip. My tire fitment is pretty flush, and even here, I've had to grind the rear fender lips, and also tuck and fold the tabs of the front fender liners.
So the critical travel is from square compression to articulated compression is going to be super close.
To your point, maybe @ChattTNUJ200 should look into a body lift. That will go a long ways to making things work. While also gaining appreciable offroad body clearance at the bumpers. Also pulling/rolling and trimming fender lips could all help maintain all that sweet travel with aggressive offsets.
This is 37s with body lift, pulled, rolled, and trimmed fenders.
Last vestiges of spring before desert season ends.
Sorry forgot to call @Boston Mangler @sdnative @TeCKis300
6112/ with 33s aired down to 20 or so is so much fun. Explored the northern parts of Anza borrego with some camping buddies. Did a little bit of everything, high speed, technical, crawly stuffs. Lots of fun.
Weathers has been great and the deserts calling. Glad you're getting out there. Definitely down next time you head out!
You going ot the dark side @Sajan??? Sticking with Mobil1 0w40 for the LC, Macan and Skid steer. The 992 is on LiquiMoly 5w-40 C40.
siberian
siberian
Macan - sticking with the 0W-20 but the Cayman I am doing 5W50 (switched from 0W-40) Mobil 1
LX - switching to 5W30... I live in hell and I am supercharged..
Meh, it's ok. Putting the JBLs in the dash made a bigger impact and only took about 20 minutes. I might swap out some of the focals
Anything you'd recommend, like mix of a la carte components (speakers, amp, sub, etc)? I'm just looking for a simple audio upgrade, not some professional/competition level system overhaul.
I'm still on the fence on the supercharger. It definitely needs more power for steep sand climbs. This hill was quite difficult to get up, more power would have definitely helped.
I'm still on the fence on the supercharger. It definitely needs more power for steep sand climbs. This hill was quite difficult to get up, more power would have definitely helped.View attachment 4116978
In my professional opinion, you should get the supercharger. Because power.
If you want, I would be willing to test yours on my vehicle for you.
Wife went to work so took advantage of the empty garage. Pulled the skids off, changed the oil and filter without spilling anything! OEM filter and had some donated Mobil 1 EP 0W-20 from my brother so used that all up. Flushed the power steering reservoir, and rotated all five tires. Oh as I promised @Boston Mangler I finally installed oem black lugs.
Coopers have about 30k miles on them, shoulders and tread blocks still look great. Want to switch to nittos but I can safely get another 25k miles out of these.
