Where would one get the front and rear spacers?
I homebrewed and stacked a LC200 OEM spacer and aftermarket rear spacer. Easy button today is to to get a 13mm E&E Offroad front spacer and a 30mm rear spacer on Amazon (correction to above as I'm using a 30mm, not 20mm rear spacer). Note that spacers will work different for an LX570 where it reduces hydraulic preload pressure, versus an LC where it will create lift while maintaining ride quality.
Truck looks amazing. I'm guessing with those bigger front shock spacers, you had to replace the top shock mount bolts for longer ones? I thought I read somewhere that the biggest spacer without changing out the bolts was 13mm. I've never considered body mount spacers. Did you do the install on those yourself or is that a bigger job than DIY (i.e., without a lift)?
Thank you! Yes, I used longer aftermarket front studs. Totally doable DIY with a floor jack, jack stands, and spring compressor. More info here
Probably no surprise, but I've been a big proponent oh AHC. Damping always dialed in regardless of load. Large fluid volumes and remote accumulator damper that stays cool with extended off-road travels. Actively pressurized for long term performance and durability. Combined with unique traits of adjustable height, load handling, and multi-rate springs for anti-brake dive and handling, there's a lot going for it.
But where does it come up short? Suspension travel due to shock length. Because length dictates maximum suspension droop of the suspension, it has until now limited travel...
- TeCKis300
- Forum: 200-Series Cruisers
