Been using for the past 8 months or so and, apart from a few connecting glitches once in a while, it is solid.Yeah Beatsonic.
Thank you!!! My wife has been on my ass to find her something like this. She gets so pissed when her Stanley tips over as she rips around corners.Installed the BH3D cup holder. Had to clean up 15 years of someone else’s mess first. This is going to be much better than the stock holder.
Step 1: destroy all Stanley cupsThank you!!! My wife has been on my ass to find her something like this. She gets so pissed when her Stanley tips over as she rips around corners.![]()
Added an inverter to complete my electrical setup. The stock inverter was falling short of charging my laptops. Wanted something that could also power the Nespresso machine at camp. Tested and works great. Trying to decide where to mount the inverter remote.
Took inverter case apart and rotated the display or it would have been upside down or I would have had to run power to the left side.
Mounted between the second row and ADGU drawers. It's connected to a LiPo battery on the driver side of the drawers with 2GA cable. Also replaced the Victron DC 12/12 360w 30a charger with the newer and smaller Victron XS charger 700w 50a which charges the LiPo when driving. It's mounted to the side frame of the drawers, much more compact and runs cooler. Ran a dedicated 4ga cable from starter battery to rear, underneath truck that connects to Victron charger. Power enters cabin on rear left grommet under truck. A little bit of a hassle getting behind the rear side panel with the drawers in place.
www.coolgear.com
That's cool and great price.If you're charging through USBC I recently got one of these and it has been great. They make a couple different options with two ports (but less power on each) or USBA, etc.
ChargeIt! Mini 100W USB-C PD 3.0 Surface Mount Charger – Commercial Grade
This High Power Single Port USB Type-C Industrial hub that complies with the latest USB-C and PD standards. Intended for use in PC power adapters, mobile chargers, car chargers and power bank applications. This charging hub provides one 100W USB Type-C PD port. USB Type-C PD with PD 2.0 & 3.0...www.coolgear.com
I credit the roof rack delete There is a great spot inside the grille to attach that Noco unit easily with a zip tie, only need to drill two small holes. When you remove the core support plastic cover, on the drivers side air guide next to the headlamp.Trickle charger with easy access plug. Not pretty but practical.
Will work the growing rat nest next winter, as well use smaller loom over power cord so that I can replace the ziptie with a factory fastener.
I ended up going the SAE harness route. I have this on all my cars and power equipment for quick plug in.There is a great spot inside the grille to attach that Noco unit easily with a zip tie, only need to drill two small holes. When you remove the core support plastic cover, on the drivers side air guide next to the headlamp.
That leaves enough cord to have it stowed in the lower grille slot where it’s less visible, and less bulk on top of the battery.
Great device though.. served me well when mine wasn’t being driven daily.
Thanks for the ideas, might move it there in the final revision or use the plug and get it out of there altogether.There is a great spot inside the grille to attach that Noco unit easily with a zip tie, only need to drill two small holes. When you remove the core support plastic cover, on the drivers side air guide next to the headlamp.
I have a lot of stories about "great personalities"....May the luck be ever in your favor, Mr. Potter - Gandalf...probablyI have scheduled an alignment in the morning with a new to me shop based on a recommendation from a dude I bought firewood from a couple months back. I’m nervous as hell to turn my keys over to places I know so this is like a blind date and all I’ve been told is she has a great personality…
May the Cruiser gods bless this blind date with the potential for long term repeat and accurate dependable alignments.
My alignment shop is one of the few places I trust with my keys. Known my dude longer than my barber.I have scheduled an alignment in the morning with a new to me shop based on a recommendation from a dude I bought firewood from a couple months back. I’m nervous as hell to turn my keys over to places I know so this is like a blind date and all I’ve been told is she has a great personality…
