Did cleaning the seat belts make them retract any better?
After cleaning my seat belts with purple power and Oxy clean stain remover, my seat belt feels 10 pounds lighter. It retracts so smooth now. I keep reaching for it on the floor next to the door where it used to sit if i didn't manually push it back up to make it retract, but its not down there anymore. It retracts every time and its always sitting on the Side of the seat against the pillar where it is supposed to be.
I finally got around to finishing up a couple things:
I fabricated a bracket for the winch control solenoid, then mounted/wired the winch, then wound the rope on the spool.
I got the Depo black headlights installed and the grill painted to match.
Those lights, especially with the black grille, are CLEAN. Where'd you get those?
I would recommend just pulling the belt all the way out, using a clamp of some sort at the top so it doesnt retract, then place a towel and bucket with mild detergent on the seat and soak as much of the belt as possible. After soaking for 10 or so min, fill the bucket with fresh water and rinse the belt. Then let it sit on the towel and dry for a few hours.
That's why I did with mine and it works perfectly now. I didn't have to take apart anything.
Did the same with good results as well.
What did your seat belt cleaning consist of? I really need to do this!
Pulled belt all the way out and clamped it at the top so it would no longer retract, closed the door. Purple power and oxi clean stain remover, sprayed it on, scrubbed them with a brush then rinsed off with water hose with a sprayer on it that made the water pressure really strong coming out of the hose. Dried with towel and then opened the door and hung them on the open door to dry in the sun. Repeated process until they wear clean as new.
I had luck unbolting the bottom, pulling the seatbelt out as far as I can and closing the door on it. Then pressure wash it.
I might have to go home ant try this tonight! Thanks!
Fixed my '03 LC sunroof that wouldn't open all the way for the last year or so. Check it out -
Good job. I noticed you were holding your sunroof button while it was opening. The buttons are one touch, you just push them once and they open or close, kinda like your drivers side window only you wont feel a click. Just push for a second and release and it will fully open or close.
Thank you! I need to do this myself, but I always thought I need to dismantle the belt to clean. This is a lot easier!
Came with the shocks. However I will remove them from the front and leave the back ones on.
They are sweet shocks for sure.
I have had my Icons on the truck for about two years now. The shaft is now slightly pitted by rust after a couple winters. I would like to have something that keeps things from impacting the shafts.
If you're dead set on removing them, please consider giving me an opportunity to take them off your hands.
