Installed new Depo headlamps from group buy
The screw on the back side of the unit will adjust up and down. 8mm ratcheting wrench or socket is needed.
It's interesting, as mine plugged in just fine without any modification.
Attention Dremel boys.... The connectors fit fine. When you first insert them the lip on the Land Cruiser side hangs up on the Depo connector. Simply tilt the Depo connector slightly as you are sliding it in so it slips past and what do you know - solid locked connection.
(posted in the other thread as well)
Here is another option for securing the top tab.
What bulb number is the little one below the head lamp? The one not included with the lights.
Looks great crimsonaudio! Did you paint or plasti dip your grill?
Thanks - I plastidipped the grill and rear badges with the Anthracite Grey Metallic:
Anyone change out bulbs in depo lights? If yes, what is recommended? They are pretty weak.
I bought some 'upgrade' Sylvania bulbs as I assumed they headlights wouldn't come with any. Never installed them though as I thought the output from the Depo's was much better than stock anyway. Maybe I should give them a shot...
I dropped some Silverstar Ultras in there and while they aren't anything like the HIDs in my wife GS460, they're appreciably brighter / whiter than the stock bulbs that came in them.
Good to know, I think those are the ones I have at home. Are they more white as well, @crimsonaudio?
Yah, they're about as white as I can find in halogens.
