Got me some new headlights from Bell Lexus on the BF sale. Only passenger was busted, but I replaced both so they can be matchy matchy.
Nice !!!!!!8 new denso coils and ngk spark plugs
Im pretty sure the ones I pulled out were the original ones as 7 of the 8 coils were cracked. 3 put of the 4 passenger plugs were cover in oil so I guess I have to add seals the the list of things I should do.
Get new corner lights too before they get discontinued. They’re very cheap compared to the headlights.Got me some new headlights from Bell Lexus on the BF sale. Only passenger was busted, but I replaced both so they can be matchy matchy.
Welcome to the clubWhat i didn’t do was watch my odometer. Missed my LX rolling over 200,000 milesView attachment 4047185
I think I have a set of new corner lights that I bought for my 05. $100 shipped. DM me if you’re interested.Yeah that is a good idea especially since one has a busted tab (I didn't do it).
Went to Azusa Canyon for some casual wheeling and to watch the mud, and while straddling a rut, my drivers tire slipped into it and clunked a rock in the rut, after pulling out my steering wheel was turned almost 90deg while going straight so i knew something was off. Visually it was off castor by a TON but it limped home fine. I figured i tore the alignment out of it, but when i got home some simple comparison measurements showed me something was more off. The upper control arm was sitting much lower than usual and had actually made contact with the AHC Shock putting a dent in it, and the ball joint was all bound up.
Finally after measuring the distance between the top of the knuckle arm to the edge of the hub i found a 0.5" difference, concluding that the knuckle arm was bent. Found another one within an hour from a legendary local guy who parts out landcruisers and was back home with the new spindle within 2 hours. Cleaned it up, fresh coat of paint, fresh grease in the spindle bearings, and it went back on the same night.
Boys i wish i bought an 80, i love this truck, it rides like a dream, has tons of power, but i'm scared to beat on it too hard with the IFS, and it's so so heavy, i've rocked two sidewalls now by compressing the tire against the rim at like 18psi, on wildpeak at4 c loads with the 10 ply sidewalls. In hindsight get E loads, the extra fear i have driving over brutal rocky climbs is not worth the softer ride. I just want something i can beat the hell out of and fix with my welder, and not have to order expensive oem parts from japan. Or go full send with a SAS!
Just look at that…Went to Azusa Canyon for some casual wheeling and to watch the mud, and while straddling a rut, my drivers tire slipped into it and clunked a rock in the rut, after pulling out my steering wheel was turned almost 90deg while going straight so i knew something was off. Visually it was off castor by a TON but it limped home fine. I figured i tore the alignment out of it, but when i got home some simple comparison measurements showed me something was more off. The upper control arm was sitting much lower than usual and had actually made contact with the AHC Shock putting a dent in it, and the ball joint was all bound up.
4 - 6 weeks away from producing a long travel kit for the 100 series / LX 470. The kit will add +2 width, push the suspension +1 forward...
I wouldn’t buy from Amazon or eBay. Densoproducts.com for me. To each their own.
eBay has spent a lot of time and money trying to legitimize itself in the world of marketplaces. They have a pretty robust return/refund policy. And well Amazon is Amazon you just have to do the sniff test but they basically take anything back.I wouldn’t buy from Amazon or eBay. Densoproducts.com for me. To each their own.
I wouldn't personally buy it already done, but i was eyeing this sick SAS's 470 on marketplace for 30k, which i don't think is horrible. Depending on how well it's done, Someone will have fun Facebook - https://www.facebook.com/marketplace/item/786813907082984SAS is definitely a possibility, but it's a mountain of work. And the 80 is still "better" in the end for being all OEM and easy to fix.
But I wouldn't go back, no way.![]()
