After years of being annoyed by wind noise at highway speeds coming from the corner of the driver's side door - right above my left ear - and not being able to resolve it by adding some extra sealing to the door seal, I discovered that the window rail had slightly pulled away from the corner of the door frame. I theorized that it was allowing a small amount of air through the seal once the air speed was high enough to open a flow path.
I tested this theory by sealing it on both sides with literal duct tape and chewing gum. I am overjoyed to report that this has resolved the issue.
View attachment 4042801View attachment 4042802
I'll get in there and seal it up for real once the weather stops sucking. In the meantime, I cannot begin to tell you how much of a relief it is to be rid of that noise![]()
That sucks....and hurtful irony, that's right where they all break while installed as well...I was going to replace my broken third brake light, but this:
So instead I replaced the muffler.
Same problem here. Window track rubber separated at that top corner. Contemplating replacement of the track rubber, or a seal it up hack job...
You guys made me look at my 04 project, is this some kind of bad casting?That sucks....and hurtful irony, that's right where they all break while installed as well...
The cost of a replacement part isn't hateful but I don't know how involved the actual work is.
In my case it seems like it's going to make the most sense to just put some black RTV or similar in there and call it good.
Good catch. I used Amayama's epc-data offshoot site to get the part number and picked the wrong option.FYI…
It seems that the window glass run, Part # 68151-60031 has an updated version…
Latest version is part # 68151-60032. And is 1/2 the price of the older version… from Amayama.
The 68151-60032 part is the ONLY option available from Toyota Parts Center Online.
Not difficult to replace the door window run.
Check this link… charm.li
Free online repair solutions…
Repair and Diagnosis — 2002 Lexus LX 470 V8-4.7L (2UZ-FE) Service Manual | Operation CHARM
Detailed repair manual for the 2002 Lexus LX 470 V8-4.7L (2UZ-FE).charm.li
Hi SnowmanI use partsuq for the diagram, input that number into a Toyota dealer site and it typically gives me the updated PN.
Those window seals are gravy, did them when I first picked up my cruiser
Hi Snowman
Am suffering a similar wind noise issue in the top corner of my drivers door. I have two layers of sound insulation throughout my Landcruiser a butyl layer and mass loaded vinyl. I am now tracking down one of the next level of sound annoyances one of which I note others have resolved with the replacement of the door run rubber seal. Am not able to decipher the appropriate instructions from the manual but assume I need to remove the door card to get access to remove and replace the door run seals. Please let us know if I am on the right track and if there are any key points of note in the job.
You can drop a lot of coin to replace it, but honestly you can glue it back together (I used clear epoxy) if your OCD will tolerate it. It will function completely and no one will even notice.You guys made me look at my 04 project, is this some kind of bad casting?
You should!I feel like by the point I should know the point of doing this but please enlighten me
You should!
The coin covers a plug that's inserted from factory, coolant passes through the throttle body to warm it up on really cold weather, and that plug started leaking. I can replace the TB for $$$$ or try a quick repair with a suitable sized coin and epoxy glue, as of now it seems it's working.
Not unique to our vehicles btw, many cars have the coolant flow in the TB and these plugs are prone to leak after a few years, mine took 20 years and almost 300k miles to do that.
If you're talking about these:Hi Snowman
I like the license plate.
