100 series long travel #ih8torsionbars!
I had coilovers Before the long travel and it rode like a Cadillac, it was maxed out on lift because the cv angle issue, the kit I designed allows for a lot more lift for tire clearance, coilover allows for insane travel hence the bump stops, torsion bars were the worst design ever, should have put the sequoia suspension design on it. Toyota really f-uped by not keeping Solid axle or going to coilover. I redesigned the entire suspension from the ground up, boy does it not want to be lifted!
Hi Bama - love the build!
You mentioned here that you was running coilovers before the long travel conversion - what was the shock specs/part number or model?
I’m look at just ditching the torsion bars and running a coilover. Not too concerned about the height/long travel - over here in Australia, they are pretty strict with vehicle hight 😅
Dood! Super cool.
I have a question though! I've got 'too much' droop in that I get ridiculous toe-in when at full extension on the front end. Does your tie rod adapter system actually help maintain proper geometry throughout the front wheel travel? If yes - any chance you can tell me what parts you used to build it?
I've been struggling to figure out a solution that works for me. I can't really lower the rack itself, the tie rod brackets on the knuckles would require some good engineering to offset them higher, and no one makes a flip kit that I've been able to find.
Thanks in advance!
do SAS, 10 times easier and cheaper, way more durable with less moving parts.
Build finally done!
Specs: 6” lift, 4” wide long travel with king coilovers, high steer kit, hydro bump stops, limit straps and swaybar quick disconnects! 10 inches of travel! All hardware upgraded to 3/4” grade 8. Kit is 100% bolt on besides the bump stops.
Wow…..I have gone for my 100 series conversion with kings 2.5 coilovers, lower and upper control arms changed with bump stops but no lift and my tie rods and it’s boots are rubbing the shock on full turn, any ideas, as I can see that your amazing build is completely free of this issue, can u share what have you done….!
Finally, let me say it’s an amazing ride you have built for urself, happy Ridding !
What lower control arms are those? Did you custom build them?
Got anymore pictures of this setup?
Did you build these lower control arms? If not, who manufactured them?
Kind of crazy that this guy in Pakistan was able to do a coilover conversion but the best shops in the US say it’s too difficult and or too expensive.
Not really. Labor overseas is cheap and that makes many things possible. It is absolutely possible at many shops here if you want to pay them a lot of money but coilovers alone have little benefit. If someone does feel the need to throw $15-$20k at this platform they would probably be better off SAS.
Yes really lol
Kamono Concepts / Filthy4r on Instagram is 4 - 6 weeks away from producing a long travel kit for the 100 series / LX 470. The kit will add +2 width, push the suspension +1 forward, and will allow for coilovers, bypasses (TBD if there is room for them), and bump stops.
He has quoted me $5.8k for a pre-welded kit (DIY kit is approx. $4.4k) including new CVs and knuckles (as well as UCAs, LCAs, shock tower, and all other necessary hardware). Note, this does not include the cost for shocks.
It will be going up for pre-sale in the next week or so.
Any idea on who is making the axles?
Hopefully this kit turns out good. I’m a little skeptical when all their website has is a bunch of cad images and no actual pictures of suspension they have fabricated.
Check out his instagram (Filthy4r) for pics of some of his work.
Oh nice, that gives me more hope. I only looked at the Kamono Concepts page and the website.
