Looking at cheap stuff on ebay. Not excited about paying OEM prices.the trim on my lx is broken as well, any idea where you're going to source new pieces?
Those system too lean codes are very hard to fix, sometimes you can clear the code and it'll go away for good, sometimes you can replace just about everything and the code still comes back. We don't fix cars that comes into the shop with that code, along with any evap codes, simply too many things related in order to fix it. O2 sensors would be a good chance to get rid of that if you did the aforementioned
Fixing lc Evap codes is a nightmare. Spent about 2k so far chasing possible symptoms.
Thanks for the kind words mate, very much appreciated!
Went and played in the snow to get a Christmas tree. Not the best weather, but it made things more exciting.
The wind was gusting bad and blowing trees over. This one fell blocking the road right as we got there. Luckily enough my small saw wasn't ready to go so I took my big saw. It made short work of that big tree.
Is that proper trail etiquette to cut the tree into pieces and remove it? We had a fallen tree like that one time but we had no chain saw, or a chopping axe for that matter, we just tied it to the front of my truck and pulled it to where it doesn't block the path anymore.
Also fixed tilt motor. The ribbon cable had come out a bit. Pressed it back in and new tape to hold everything tight and my tilt works again.
First I've heard of this, did you access through the little side doors or have to remove the wheel or column trim?
