I spent a few days up at my cousins place in Linville. Ended up getting a tree while I was there. I love that place. There was something nice about strapping a tree to the top of 80 and coming home.
Spent the day before and the day after Turkey Day working on Bertha. Got the tank finally plumbed after wild goose chase for fuel filler hoses on Wednesday (hoses have two diff diameters at each end - go figure!). Then Friday got the fuel pump installed and the rest of the fuel lines linked from old hard lines to the new injector lines. Brian at ACC finished off the wiring of the computer & harness to the steering column and he checked the coolant lines for leaks with a vac tester - then we filled her up with antifreeze, oil and gas. Came really close to getting her turned over - but gotta double check our wiring and add some solid ground wires to the body. May also have to shim the starter motor - seems to be struggling like the teeth are engaged too tightly.
Sooooo verrrrry clooooose!
Cut a factory fabbed bumper off of the junk cruiser, cleaned it up, painted it and put it on the 40. Cleaned up and painted the 8274 and bolted that bad boy up... I need taller springs now, that thing weighs a ton!!
put in a fuse box under the hood of the engine less cruiser to run items such as heated fuel filter and glow plug heater.
Mounted 2 lawnmower/ford style solenoids in the bay, one for starter other for glow plugs.
Installed a GM headlight relay for the electric fuel filter heater.
Drained fuel tank/cleaned lines.
Removed the last of the Smog system/anything gas related that i no longer need.
Ran wiring for new items being added. Cleaned up some rust under the battery tray.
Hopefully UPS will bring me a package from AA today so i can put the engine in the bay. Looks like i might possibly be able to re-use factory motor mount brackets but i won't know 100% until i can bolt my ranger OD on.
Still need to finish my wiring for the electric fan.
Got custom power steering resevrior bracket made, now i just have to mount her in the bay and plum the return line.
Found that the stock tranny mount is broken, got to order a new one. The stock clutch slave/master cyl were also leaking slightly. I need a pre 86 slave cyl anyway so i have the adjustable tip. It's also got a smaller body which will clear the HUGE diesel startetr much better.
I seem to have missed the post where you removed it? Figured a celebration was in order if you did.
Jeremy
