What is the maximum thickness you can bend with that? I bought one of these that seems to work well with my 20 ton press and pneumatic jack. Works well but, it will not handle larger/thicker jobs.
Thanks, man! Cheers!School ain't cheap on Landcruisers. Congrats on plowing through the birf job despite the obstacles! You've passed the right of passage!![]()
It says 16 gauge, 0-135 degrees, 24” W capacity. You can bend box’s with this one also.What is the maximum thickness you can bend with that? I bought one of these that seems to work well with my 20 ton press and pneumatic jack. Works well but, it will not handle larger/thicker jobs.
TREEMy hammerhead 3yr old son found my sunroof visor and tried to seesaw with it i guess. Errrrr! I think i might try and epoxy it. Thoughts? View attachment 2793037
The nut doesn't fall too far from the tree.....silly.FISH
egg
I'd cut a narrow section of aluminum to act as a backer and mix up some JB Weld to slather on the break and the backer-to-plastic areas. Fixed my broken upper door panel plastic that way and it's stronger than ever. It may not be pretty but it will be fixed.My hammerhead 3yr old son found my sunroof visor and tried to seesaw with it i guess. Errrrr! I think i might try and epoxy it. Thoughts? View attachment 2793037
Plastic weld it or stitch it and epoxy itMy hammerhead 3yr old son found my sunroof visor and tried to seesaw with it i guess. Errrrr! I think i might try and epoxy it. Thoughts? View attachment 2793037
Solvent weld.My hammerhead 3yr old son found my sunroof visor and tried to seesaw with it i guess. Errrrr! I think i might try and epoxy it. Thoughts? View attachment 2793037
I've found that the Weld-On product works great with acrylics, but causes crazing with Lexan (polycarbonate).You use the solvent glue and join the 2 pieces by a thin piece of lexan on each side.
