Send it back for a full refund![]()
Perhaps you quoted the wrong post, it was @goranvolvo questioning the LCP fan, I was questioning my eletrical ability
Perhaps you quoted the wrong post, it was @goranvolvo questioning the LCP fan, I was questioning my eletrical ability![]()
i do not have much pictures , but it is straight forward get the fan and look for best way to fit it in if someone cant figure it out probably have someone to do it for you
it took me a lot of measuring and looking for right fan and relay so biggest problem is solved
so get condenser fan for Suzuki vitara and cooling fan relay from Volvo ,Volvo relay is easiest relay to wire all you need two wires to make it click (google)
Finally sitting on her own weight after several months and countless hours. Funny thing is after being cooped up in the garage every weekend, I'm not even itching to go rock crawling. I just wanna drive on boring dirt roads and go camping
Now you are officially an 80 owner. Overbuilt rug that’s used on roads a Camry could drive on!
That was too close to home...Now you are officially an 80 owner. Overbuilt rug that’s used on roads a Camry could drive on!
. So now I'm waiting until Wednesday to get the new calipers and replace both front ones, at least they're under warranty. After that I will flush all the brake fluid and I guess have a basically brand new brake system.i do not have much pictures , but it is straight forward get the fan and look for best way to fit it in if someone cant figure it out probably have someone to do it for you
just to be safe so i dont burn my switch and wiring that relay uses ground for off-on function so there is no load on switch , you should use relay for almost all add-onsI like it. Mo' bigger, mo' betta. But what do you use the relay for?
We dont use or NEED relays with our set up, just another item to fail and our goal is to keep it simple so the electrically challenged can wire it and understand the wiring. Where do you relocate the horns to?
Our wiring diagram
Will be updating installation notes later today![]()
Really LOLYou seriously run the current of a radiator fan through a dash switch??? Sounds like a really terrible idea IMO.
Yeah I don’t care how much that switch is rated for, I would never run that kind of amperage through my dash board. Needless to say, I’m very cautious about my electrical.Really LOL
Switch is rated at 21 amps by Toyota the fan FLA is 7 amps fused at 10 amp where do you see the problem?
