bottle opener
I often find myself relaxing under the truck. That would be a neat feature.
Wife can't find you there
bottle opener
Your fronts are wrong too. Driver's side is just barely staying up on the step, I'm not 100% sure but the PS looks like it is about 180 out. Can't tell about your DS rear.
There is an obvious step on the lower spring pads.. the end of the coil wire should butt up against that step.
Thanks guys. Got em' spun around. I never saw that shelf when I was installing. I think I was so irritated working with the strut compressors and sweating my butt off that I didn't see that very prominent shelf on the front side. It is a PITA compressing those heavies. Thanks for your help. Sits good now.
What about brake lines?Did you loosen all your control arms and pan hard bar? If you do the springs have tons of room and need nothing to install them. The picture below (863J)shows how much room you have when you loosen everything. You should always when installing a new set up loosen everything and retorque after everything is installed and you are sitting at right height.
Travelled back from Northern VA back home to SC and took the scenic route. Sorry for the off-scant pictures. My daughter was being a smartass after I asked her to take some pictures along the way. I got home and celebrated 18 years of marriage!
I think our low last night was in the high 80's.
Humidity is bad, but when you get over 110° it doesn't matter. We actually are more humid than normal for this time of year.
Yes. Yes I did. She thinks I'm handsome so let's not let her know otherwise. I'm gonna ride this train for as long as I can.You definitely married "up"! Lol.... Congrats! Here's to 50 more!
Was sationed there and actually miss it. Lots of BLM and Joshua Tree land to explore, and once youre acclimated it can be quite fun. A steady intake of fluids makes a big difference and I still have the habit of stepping into any shade when not moving.I used to say the same thing, then I started going to 29 Stumps on our yearly desert training. The East coast has humidity.... yes, but get out in that 110-115 "dry" air.... and you feel like a dry roasted peanut! I'll take my coastal 90-95 w/ 85 percent humidity any day!!
