What did you do with your 60 this weekend?
Started on the knuckle rebuild. Found some interesting looking grease and corrosion.
Breaker breaker 1-9!
Went crazy with my communications set up. I now have GMRS, HAM and CB. Had to fab a bracket so I could stack the HAM and GMRS.
Firestick CB/FM Antenna with a splitter inside the center console.
MIDLAND UHF/VHF with a splitter inside the center console
@schuy2147 Looks like beef tallow. RFK Jr. approved!!!
@joebattle1 Prepare for launch! That thing looks like a space ship inside.
Now I just sit in my driveway listening to the airport renta car shuttles talk to dispatch and each other at the Oakland, CA International Airport on the GMRS. Most of the conversations are centered around A-hole customers and what they are having for lunch. :flipoff2:
Well needed wash, so much sand !!
Balanced rims (3 bent !) Will probably need beefier rims although weight rating is fine.
Test fitting custom long range fuel tank ...
Some minor adjustments but overall happy with result.
It will fit a little higher after installation.
Used stainless steel 304, not sure if I need skid plates or not will see after installation.
Replaced the rear Dobinsons shocks with appropriately sized Bilstein 33-233970 which increased my uptravel about 3” for a total of 5”. So I’m removing the 3” bump stop extensions (left) and only need 1/2” extensions (right) for the factory bumps, which I made from some scrap aluminum block I had lying around.
