What did you do with your 60 this weekend?
Much needed oil change, new rubber, quick trip over to Bend and then down to Salem to pick up a pallet of wine for my neighbor. 42 cases of Pinot slightly past its prime. I got two for the ride.
Finnaly found an alternative to the old gearbox shift knob, its much bigger beefier and feels much better.
also found the elusive hood support fasteners (plastic that holds the hood arm when closed and the plastic one that keeps the arm in place).
DIY 2 LED strips for lighting the engine bay still need to add a switch and fuse but world of diffrence!!
Finnaly found an alternative to the old gearbox shift knob, its much bigger beefier and feels much better.View attachment 4101798also found the elusive hood support fasteners (plastic that holds the hood arm when closed and the plastic one that keeps the arm in place).
View attachment 4101800View attachment 4101799
Redline carries the prop rod holder. Just snagged one while getting a few other things.
Couldn't find them in Egypt, cost 1 dollar from China
Skniper,
Sometime in the past with the PO, there must have been an explosion! I am removing layers of grease and grime from the front end and all along the passenger side. I know the front seal leaked, the water pump leaked, the power steering pump leaked and the push rod cover leaked. So with all the leaks, my truck fits in with all the rest! I may have over done the cleaning along the way...
Custom fuel tank, new fuel lines car was originally 3F and previous owner converted with out swapping tank and lines.
Next step is pump and injectors calibration.
Skniper,
Cake batter grime is the worst. You’re doing the lord’s work, carry on!
Was making my way up to Kernville CA to get away from the city and work on my project 86 Ford crew cab 4x4 with my girl and my dog.
But my 60 decided it didn’t want to go! Stopped at a 7 eleven pulled the plug wires one by one with no difference on #4 and #5.
So drove a little up the ways to an oreillys to buy a spark plug socket and rent a compression tester. And my numbers were not good 30 lbs on number 4 and 5.
Pulled the valve cover to make sure valves were not stuck or pushrods were not bent just to make sure.
Confirmed the head gasket gave up the ghost 103 miles into my journey.
Called the tow truck and headed back home. 😢
