- Joined
- Jul 18, 2014
- Threads
- 8
- Messages
- 257
Using my 62 as a defibrillator
You know you love us.Not sure if I love or hate you all with this right of passage thing.
Sweet Honda, what year? My dad had a 750four, strong ass bike, I spent many many a mile on the back of it.
Installed my warn winch and wired it in. Works great went with synthetic rope.! Also replaced all the window felt and gaskets including the stationary second door window.
Pulled my dash bezel. Had to get back there to upgrade my Firstech/Drone Mobile alarm, but figured I’d also order some new LED dash bulbs which I’ve been wanting to do for some time. Now I just gotta wait for them to arrive as I don’t want to put the dash bezel back, and take it out again. Not too bad to get the bezel removed. Just had to pull the speedo cable to have some more room to work. And I had the NCAA games on while working!
I first took the door card off. Lowered the window. In the front I left the windows in and pulled the old channel out with a needle nose pliers. The front comes in 2 pieces. The little leg up front with the new channel I slid down the metal channel using the window as a guide. I used white lithium grease in the channel or soap. Either one works. They slide right in place. Same goes for the larger channel on front doors. You basically just need the soap for the horizontal channels that go down into the door. The upper part just pushes in place. Then I took off the outer horizontal weatherstripping against the glass using a screw driver between the chrome and the weatherstripping and quickly punched down on it pushing the clips into the door cavity. Then I replaced them on the new piece with the chrome and clicked it all into place in one shot with window in. Don't try and install horizontal weatherstripping leaving the chrome on the door. I couldn't get the clips behind the chrome strip to click in place while the chrome stayed on the door or I would keep dropping the clips into the door cavity. I did it all off the rig and then you just put it on and click it against the glass by pushing down on it. It definately clicks into place. Easy.Any advice on how to replace the window felt? I've had mine sitting in a parts box because I can't find any info on it.
big CBB fan? Need an account??Pulled my dash bezel. Had to get back there to upgrade my Firstech/Drone Mobile alarm, but figured I’d also order some new LED dash bulbs which I’ve been wanting to do for some time. Now I just gotta wait for them to arrive as I don’t want to put the dash bezel back, and take it out again. Not too bad to get the bezel removed. Just had to pull the speedo cable to have some more room to work. And I had the NCAA games on while working!
OEM rotors. Part number 43512-60100. $125 CDN each. Get 12 new studs while you're ordering. 90942-02053What rotors are those? You got a P/N? I need to pick up a set for when I put mine back together.
Thx
Any trick to getting old studs out and new studs pressed in?OEM rotors. Part number 43512-60100. $125 CDN each. Get 12 new studs while you're ordering. 90942-02053
HF 20-ton shop press works great, for both removing and installing.Any trick to getting old studs out and new studs pressed in?
This is the way.HF 20-ton shop press works great, for both removing and installing.
