I got the H4 housings from Susquehanna along with the harness, H1 housings I found cheap on Amazon as an open box deal. All are e code housings. Couldn’t pass on the price. I was prob at about $365 total for everything. Money well spent IMHOThis is next on my to-do list. Which housings did you have to get from them?
Man, I wish I had known this was happening. Would have loved to bear witness to the swap. Oh well, guess that means I'll try to wrangle you as an experienced bystander when I pull my tranny here in the next few month. You have been formally warned!Installed a brand new H55F with a rebuilt transfer case. Used the long spline input gear. What a massive improvement this is! Quite a bear of a job to do alone, but it can be done! Don’t have many pictures because I was two days behind schedule...View attachment 2549356View attachment 2549354View attachment 2549357View attachment 2549355
Did the much needed H4/H1 headlight upgrade.
Susquehanna Motorsports harness and got the Hella housings from them and Amazon. Light output is amazing compared to the old sealed beams. View attachment 2561443View attachment 2561444View attachment 2561445View attachment 2561446
The weekend started today as I changed the clutch fan on my 84...wasn't too bad. I didn't have to take off the belt. I did; however, did disconnect the top radiator hose which made the ease of it coming out better. I ordered an Aisin Fan Clutch off Amazon (with tax was $75), which stated it would fit Osiris...it DID NOT, so don't make the mistake I made Do not order Aisin FCT-017 Clutch Fan because it's totally different. I read another forum on here and went with Napa (274336- around $57) and it was exactly like the one that came off.
Notice the difference from the original compared to the Amazon one.
Installation was smooth and I didn't have to use a special tool to turn the water pump as I used a flat head screw driver and turn it.
Amazon Fan Clutch (Aisin FCT-017) on LEFT Original Fan Clutch on RIGHT
Yeah, high beam indicator works. The high beams really turn it to daylightDoes your hi beam indicator light on the dash still work after swapping in the wiring harness?
How ‘bout that 400W of hi beams going down range? Woohoo!!
Another engine swap. R2.8, custom built HD 4L70E, New Toyota transfer case
View attachment 2561667View attachment 2561668View attachment 2561669View attachment 2561670View attachment 2561671
Let me rephrase ...it did fit but I was told by a mechanic here that the part that is going on should look like the part coming off. So if it fits on your 84 then i stand corrected.No idea what that is on the right but I assure you the Amazon AISIN clutch 'fits'. On my '84 right now. Curious, how did it not fit for you?
Hell yeah man, I got everything you need to do it.Man, I wish I had known this was happening. Would have loved to bear witness to the swap. Oh well, guess that means I'll try to wrangle you as an experienced bystander when I pull my tranny here in the next few month. You have been formally warned!
The headlight upgrade is one of my favorite upgrades!Did the much needed H4/H1 headlight upgrade.
It’s custom, the PO designed and built it.The headlight upgrade is one of my favorite upgrades!
Whose front bumper is that?
