This is really the culmination of about 4 weeks worth since acquiring it.
Issue: Power steering pump pulley was rubbing the upper radiator hose.
Cause: Man A Free bracket installed without correcting the Saginaw pump to a proper Toyota pulley.
Repair: Replaced MAF Saginaw setup with new Saginaw kit (Georg
@orangefj45 @ Valley Hybrids and Cruiser Brothers) (Pump, modified bracket, adapter bracket from George, his high-pressure line), air-pump delete idler pulley from Jim Chenowith
@FJ40Jim (TLC in Lancaster, OH). Previous Owner (PO) eliminated OEM power-steering pump bracket + air-pump adjustment bracket. Replaced missing air-pump adjuster bracket with used-OEM from
www.sor.com (great service). Also replaced upper-radiator hose with OEM from
@orangefj45 @ Cruiser Brothers.
Issue: All lights not properly working
Cause: Blown bulbs, shorted wiring, PO installed headlight relay mod with poor connections.
Repair: Removed all corroded connections, replaced/repaired wiring as necessary, re-loomed wiring and tucked as aesthetically desired.
Issue: FM antenna broken.
Cause: Unknown
Repair: Ordered CB/FM all-in-one antenna, courtesy of WagonGear.com in-stock status.
Issue: Missing light-bar from roof rack
Cause: Stolen when listed for sale on Craigslist
Repair:
Amazon $40 light bar
Amazon.com: LED Light Bar Nilight 52 Inch LED Work Light Spot Flood Combo LED Lights Led Bar Driving Off Road Lights,2 Years Warranty: Automotive(52") + OEM Toyota Fog-Light switch
Amazon.com: Toyota 00550-35976 Fog Light Switch: Automotive.
Issue: Stumble, miss under throttle between 1,500RPM--2,500RPM.
Cause: SMOG vacuum routing
Repair: Followed forum here:
My Desmog Thread
Issue: Pressurized oil leak coating passenger side of engine compartment.
Cause: Multiple signs of multiple leaks.
Repair: Replaced leaking, non-hose-clamp, non-spring-clamp, PCV valve hoses, PCV Valve, air-cleaner vent hose (back of engine compartment on air cleaner), plugged air-cleaner with
@FJ40Jim de-smog kit. Replaced Oil-cooler gaskets & O-Rings, ensured lines sealed and non-leaking, saved OEM replacement for later inspection/replacement as needed. Removed fuel pump, cleaned engine block, replaced spacer plate with OEM found on
Amazon Amazon.com: OES Genuine Fuel Pump Flange for select Toyota models: Automotive. Tested OEM fuel pump per FSM and passed test. Reinstalled OEM fuel pump with new gaskets obtained here
Amazon.com: Airtex 1414 Mechanical Fuel Pump: Automotive. Now carrying aftermarket fuel-pump as a spare. (235K miles on OE pump aint bad!).
Issue: No A/C. Compressor was diagnosed by Capitol Toyota (Salem, OR) as leaking.
Cause: Bad compressor
Repair: Replaced compressor with Denso found here
Amazon.com: Denso 471-0204 Remanufactured Compressor with Clutch: Automotive and Denso Receiver/Dryer from here
1987 TOYOTA LAND CRUISER 4.2L L6 A/C Receiver Drier / Accumulator | RockAuto. Need to return to shop with A/C manifold to swap lines, re-charge and re-test.
Issue: Install CB Radio
Cause: N/A
Repair:
wagongear.com » Antenna Mount Info & Installation
Issue: Coolant drain petcock is a mess...and sucked
Cause: Just a crappy design IMO.
Repair:
F103SX: New Generation Valve with 12mm-1.25 Threads
Took a long time
