Why?Moved front axle shackles to rear (works perfect)
job. My "87 does not have the nuts in the c-pillar so I fished those with some string to pull up in the pillar. Actually this is super easy - remove cargo panels (pop em out), then just cram the shop-Vac up nozzle up behind the c-pillar where the big opening up there is. This is best done from the rear outboard side behind the panel area. Turn on the Vac, feed the string down thru the pillar hole - voila - vac sucks it right thru! Fishing done, 1 minute tops.
Started my rear seat belt upgrade using the seatbeltplanet.com FJ60 rear belt set. It is turning out to be a little complicated, maybe ajob. My "87 does not have the nuts in the c-pillar so I fished those with some string to pull up in the pillar. Actually this is super easy - remove cargo panels (pop em out), then just cram the shop-Vac up nozzle up behind the c-pillar where the big opening up there is. This is best done from the rear outboard side behind the panel area. Turn on the Vac, feed the string down thru the pillar hole - voila - vac sucks it right thru! Fishing done, 1 minute tops.
The plan is to pull a flange nut on a stud up in there, and glue it with JB, or otherwise secure it (haven't decided the best attack yet), so the upper belt swivel bolt can be threaded. That is the only tricky thing in the job.
Also located where I wanted to mount the retractors, and drilled the holes. These go right on the "bulge" in the trim for the wiring. So I'll have to trim around them best I can.
I am taking a lot of pics and will post a thread when I'm done.
Love the Seats! I had a 2004 M3 and I miss the snug seats and the height as compared to the stock FJ60 seats. I'm a tall guy so I may do this eventually.Oh, I guess the the mounting points are different than the later 60/62...I have TORFAB brackets in my 62 mounted up nicely! Not sure if I like the Vader seats, they came out of a 1995 M3. I'm a skinny guy and they are a little narrow in the thigh area. I think I like yours a little better!
Early 60 series owners get ready....
BMW seat brackets.
Gotta give @torfab some love for letting me try out a prototype. 8 hrs or so of labor for the one side. Should get dialed down with the design changes they are going to make.
There is a serious amount of cutting involved in these. Front seat bracket, bottle jack mount, and rear seat mount pedestals all have to go.
Bracket
Front mounts - (will end up being a bar like the rear)
Rear mount
this summer (again)I would assume shackle reversalWhy?
