Sometimes you can simply look at a Land Cruiser and tell it was a product of a "quality build" and then there are times when you can tell that "quality" was not in the builders vocabulary. This is an example of the screws that were used on my rear taillight assembly. (actually this is one of the better ones, the rest had to be drilled out).
. View attachment 1909042
It actually makes the "rebuild" somewhat straight forward. You start with the assumption that everything was done incorrectly or at a minimum done poorly. Nothing that time, talent and $ can't overcome.![]()
Super shoddy right there. Some straight up Half-axx'd work.
I do not see any screws on the bottom or sides; I suspect the bent out tabs are what is used to hold it in place.how is the radio cage attached to the dash?
It's good that my guy enjoys electrical stuff.View attachment 1909855
..... or wood shims and duct tape.At least there are no wire nuts from Home Depot in there.
Not using the factory radio mount cartridge thing is quite unforgivable though, the 70 series has to be one of the easiest vehicles in the world to mount a new radio in using that.
THAT is BADASS.![]()
Did you replace speakers as well? I did my stereo a little while back only to realize that the speakers are trashed. They seem to be a little more of a pain to deal with.Light at the end of the tunnel .......
Although I don't understand a fraction of the features, Rob's got it working. My last radio was a FM/AM/ Cassette which is more my style.
Speakers are actually good and I plan to add another pair. Should be enough to drown out the Diesel engine.Did you replace speakers as well? I did my stereo a little while back only to realize that the speakers are trashed. They seem to be a little more of a pain to deal with.
Since you are on the topic of speakers....
I purchased a set of speakers to replace the 1993 factory speakers and wasn't sure how to access them.
How do you access the 4" speakers inside the lower metal dash panel ?
