Weber Tuniing Question
Boaf, do you recall if the pistons used in the rebuilt 2F were domed or flat top? Also wondering if the head was open or closed chamber?
Also, I recalled FJ40Jim mention NGK BPR4EY is a hotter plug. He’s mentioned W14EXR-U is the ND equivalent. Might be worth a try at some point.
Yep, I have NGK's. The pistons are domed as the head is also (before cleaning). OK on plugs, thanks.
You might want to pull some plugs and look for evidence of lean or rich condition as well. You will have a good baseline reading because they are new. Lean condition is hard on valves. These 32/36s are rarely the best out of the box.
Are you running vacuum from the carb to the HEI?
Vacuum advance to Carb. I will run these plugs a bit longer and replace them...
Yes on Oil driven pump by distributor, seated flat and engaged, danke.
So update: Adding @Pin_Head
  • Cleaned the fuel filter in the 38 / 38 carb, yep sediment.
  • Re set the distributor to #1 Cylinder using the BB on the pointer (for some reason, the BB when positioned on the pointer and car is running, it just stalls. With vacuum off and plugged). Wondering if I am off a tooth or so. But BB on Pointer, Rotor smack dab in the middle of #1. Thoughts on that gents? Never had this one before. Need to get this straightened out so I can adjust the Carb.
  • Test run was very good for acceleration and no more backfire fuel starvation out the carb.:bounce: The catch, I need to leave the the choke partially closed. When I open it fully when warmed up, it would stumble off the start. Wondering if that is the Idle Jets (45) causing that and my trouble keeping the the truck running when setting timing.
I appreciate all your help on this, it's been a long, long road...:skull:
Boaf
It is likely to get the distributor off by a tooth or two when reinstalling the distributor if you are not aware of the fact that the rotor turns as the distributor gear in gages the cam gear because they are helical. You need to compensate by starting with the rotor pointing two teeth back from where you want it to end up.
Set the engine on TDC for the compression stroke of #1 (or #6, it doesn’t matter) and then pop the cap and look at where the rotor is pointing. If the rotor is pointing closer to the position of wire for #5 (or #2), then the spark may be jumping to the wrong cylinder when the engine is properly timed. It needs to be pointing at the leading edge of the #1 wire so that it can also be pointing to #1 when the distributor advances centrifugally by 20 degrees or more.
PS:
If your distributor is off by a tooth or two, it is easier to just move the plug wires over one hole on the cap rather than remove and reinstall the distributor and have to worry about getting the oil pump drive engaged correctly.
OK, thought that also and will do. Never had a problem dropping in the distributor before.
Yes, vacuum pulls from DUI/HEI to base of carb.
I will pull plugs and show you what I find. What’s the best way to get what I’ll need for re-jetting? I presume I’ll need an assortment of jet options to trial and error my way to 100% smooth running.
Here are some numbers:
Main Jets 38/38:
Elevation:
SL (sea level) 1250ft 2500 3750 5000 6250 7500 8725+
F 150 145 140 135 135 130 130 125
2F 155 150 145 140 135 135 130 130
Air Correction 38/38:
Elevation:
F 180 180 185 185 190 190 195 200
2F 180 185 185 190 190 195 200 200
Idle jets 38/38:
Elevation:
F 60 60 55 55 50 50 45 45
2F 60 60 55 50 50 45 45 40
The easiest to get to are the idle jets. Do they jive with the sheet above?
Interesting information:
***Weber Carb*** Adjustment Thread
Is this a true weber or china copy? Is it from sor?
China copies had issues with shavings and is recommended to disassemble the carb and blow it out before installing ... this goes for any carb from China
Did you pull the large brass filter nut just under the inlet? There is a filter inside there
Some Weber’s run great at the timed at the bb... but... most like it at 12*
If you have lean jets at idle it affects the whole range of the carb
I would start at 55 but get a 60 as well ... too many people just get it going and are satisfied not knowing that they are running so rich
IMHO you should bump the timing to 12* ... bump the idle speed to 750 turn out the idle mixture screws until you hear that noticeable idle change and back it in quarter turn
It’s ok for now if you are out around 2.5-3 turns
You will need to readjust everything once the proper jets are in
I had seen several like it around 14*
If you think you are running the carb dry you can check ... when it does what you say... shut down the motor and using a small 1/8 dowel slide it down the vent and check the fuel level
You can see the air Correction jets on top and just past them toward the inlet you can see the open vent
This also is the reason for the notorious carb flooding on steep declines as gas pours in the air Correction jets
I like to keep it open as I can check float levels this way whenever without having to remove the top of the carb
Right now, out 1 and 1/2 turns. I have 45 jets, and agree should be around 55 or 60 for PA Altitude. First, need to iron out the distributor tomorrow. Thanks for everything...
I see, so the Leading Edge of 1 is where it needs to point. I was square dead center. Thanks, makes sense about the advance...
Also, read that the distributor is to be dropped in TDC, or with the BB lined up. I've always done TDC. Your thoughts?
Boaf
Yes, the distributor is typically aligned to TDC for the compression stroke of #1. That way the plug wires match up with the tiny numbers on the cap.
The reality is that it can be timed correctly in any orientation. Just find which direction the rotor is pointed on TDC for compression stroke of #1 and then put the plug wire in the nearest hole.
Firefighterjed, pardon me, but can we start a new thread? The 32/36 HEI has a bit different scenario.
Definitely. My bad, didn’t intend to hijack, and you’re smart to keep the info separated
I’ll start a new thread with 32/36 in the title. Maybe this one could get a title edit for specificity as well?
Thanks everyone for the help.
Thanks, thought so. Some times we over complicate things.
Right now, it runs great with the timing somewhat off. The only catch is the manual choke needs to be partially closed. I'm running 45 idle jets on my Weber 38 in Pennsylvania. Will switch those out to 55 or 60's. Also installing a new Accelerator pump diaphragm.
Thanks.
Boaf
If you are needing anything other then 180 and 155 at sea level it would be out of the norm ... but two carbs same issue that’s already out of the norm ..... boost the timing to 12-14 ... idle speed to 750 and report back
Did you open it up to see what jets you even had? Get timing set yet? Before throwing more money at it?
the air correction jets lean it out as you go up in number...but... only makes a bigger difference at higher rpm range
needing the choke pulled out to run smooth certainly indicates too lean. Should have enough adjustment on the mixture screw to go well past the recommended setting to see if you are able to get smooth idle at least on the 45s . The fact you get back firing under constant load higher in rpm range suggests it is not so far off on lower end but gets too lean higher in rev range under load. The 55 idle jets will make it richer overall. But, the fact it was behaving the same way with the previous carb is odd.
some more thoughts:
Float should adjust for full open stop and also for needle valve seated positions. Too low a float setting for seating the needle valve will make the carb run leaner as fuel level gets lower in the main jets. Most needle valve issues in webers seem to be from going rich with no pressure regulator/too high fuel pressure.
is the gas tank venting or do you get vacuum in the tank under load?
Is the cam timing correct (marks aligned when you were reassembling engine)?
do you get full valve lift on all cylinders (no worn lobes)?
compression numbers ok?
condition of pcv valve and check valve on the brake booster? no other vacuum leaks?
Thanks I agree that this happens with 2 carbs is not normal.
