Weber Tuniing Question
Florida
Fellow LCer's,
I have a 72 LC with a Weber 38 / 38 DGES Auto Choke 2F motor. Just got off the phone with SOR tech, great guy, very knowledgeable and asked the right questions. Been having trouble with my LC backfiring out the carb.
New Fuel pump, Fuel filter, New Points. It is a classic Fuel starvation or timing issue. Just want to bounce ideas off my brothers and sisters.
  • I have set my timing spot on the BB with the vacuum off.
  • Reconnected the vacuum to the Weber and adjusted the carb to smooth running. (hmmm)
The SOR tech suggested tuning the carb with the vacuum disconnected (ie blocked or in my mouth (old school) in order to have the vacuum advance activated when accelerating. He suggesting that the advance is retarding when accelerating rather than advance. It made sense to me that I need to have the vacuum advance when the pedal goes down. Below are the symptoms:
Accelerate:
  • Hesitation, stumbling and carb backfire when accelerating (like timing is not advancing on demand).
  • Sounds like a retard (rev limiter) when pushing the accelerator to the floor, then the pop until I lighten up and accelerate slowly.
Maybe an accelerator pump on Weber, bad float adjustment (checked already) or just a tuning thing.
What's up Bro and Sis? @Poser, @Coolerman thoughts?
Danke
Boaf!
Did you tell the SOR tech the 1972 OEM retarding dissy has been ditched? Pretty sure you are running an early-68 vac advance unit. I’d hook the ported advance back up and see how it runs.
yes sir, Absolutely. I told him that the distributor has a Vac advance and retard / advance dial. He seemed to get it. I'm just looking for good advance that won't pop out the carb. If I need to get a new Dizzy, OK just want to make sure I'm not pissing away money. Love my LC and enjoy it.
Boaf
Tuned the carb and found that I was leaking around the top gasket. Replaced it and converted my automatic choke to a manual. Like that!!!
Checked the float to 1.5 inches from bottom of float to carb gasket just to be sure.
Still, when going up a hill in 3rd gear, I loose power and eventually will backfire out carb. Also, hesitant on applying hard throttle in 3rd gear. Need to slowly build up speed or it will back out the carb. It seems better than before now that the gasket is replaced.
Soooo, all that said, I am ordering the accelerator pump diaphragm for the Weber. If that does not resolve, I am out of ideas.
Any Weber suggestions are very much appreciated. If this doesn't do the trick, looking for a replacement carb.
My other post on what was done with the carb and Distributor.
Thanks,
Boaf
So the carb came with the correct jets, idle, main, air correctors? There are also a range of sizes of Accelerator Pump Jets for the 38/38. They sell tools to measure them, or you can use a set of numbered drills and approximate the sizes. Good idea for the accelerator pump diaphragm, with today's gas and all.
Correct jets, yes. cleaned the carb inside and out. I would eat off it. Thanks.
The 32 / 36 wouldn't start and had no power at all.
Some items I have done since replacing with the 38 / 38.
  • Replaced spacer gaskets
  • Ground flush the studs so no air between the spacer (sure that had some issues.
Not sure I want to go back to 32 / 36. Heard from multiple sources that it is way to small.
My source describes the float height at 18mm from the top of the float to the bottom of the gasket.
Your valve lash is good?
Your PCV isn't a major vac leak source? It is clean internally?
The intake manifold has no crack under the carb? The intake manifold mates well with the head, and there is proper torque on the head studs?
Throttle action creates a squirt of observable gas in the bores? What are your current settings for the Idle Mix screws and Idle Speed screw?
Thanks Dizzy,
A great checklist:
I measured float bottom to Gasket at 1.49 inch
Brand new PVC
I see no leaks and will spray and listen again, you never know..
Yes for squirt, 2 full turns on throttle screws per Weber instructions.
Man this is frustrating. There has to be air coming from somewhere.
Boaf.
38 DGAS Tunning
2 turns might be too many, certainly on the Idle Speed Screw, and maybe for the Idle Mix Screws, but it would at least suggest where the lean condition might be coming from.
OK I may have to ask an embarrassing question. I set the fuel mixture screws at 2 turns per the factory specs. Then adjusted the Idle screw.
My stupid question: Do the Idle Jet screws (See Diagram parts 34 / 36) also need adjusting or are they screwed in snugly? All the instructions I've seen so far indicate perform the following:
  1. Timing
  2. Fuel Mixture screws
  3. Idle Speed screw
No mention of Idle Jet screws (Parts 34 and 36). Can that be my error?
Thanks Dizzy.
Boaf
The parts 34, 36, idle jet screws are for assembly only, not tuning.
If your fuel mix screws are out 2 turns, then you might need a bigger jet, or something is in that passage, or the needle-screw got buggered up when it broke off on that one side, or whatever. It is hard to say. But it means that your carb is probably jetted lean, not only at idle but across the rpm range. Shoot for closer to 1 turn out with these screws at a good rpm.
If your Idle Speed Screw (which is basically a throttle rest/stop) is in more than 1/2 turn from touching off, then it indicates a lean condition or a rich condition, depending on the status of the Idle Mix Screws and idle jets.
Thanks, on it now.
Well, Set at 1 turn for Fuel Mix screws. Went for a drive and still the same condition. Something tells me it's time for a new 38 / 38. I ordered the diaphragm and will replace that and see what happens. Thanks for all your help. Let you know. You may be right about that Fuel screw fn up the seat...
Boaf
No FPR anymore. I did not red them, think (I may be wrong) they are what came with it, factory.
Here are some numbers:
Main Jets 38/38:
Elevation:
SL (sea level) 1250ft 2500 3750 5000 6250 7500 8725+
F 150 145 140 135 135 130 130 125
2F 155 150 145 140 135 135 130 130
Air Correction 38/38:
Elevation:
F 180 180 185 185 190 190 195 200
2F 180 185 185 190 190 195 200 200
Idle jets 38/38:
Elevation:
F 60 60 55 55 50 50 45 45
2F 60 60 55 50 50 45 45 40
The easiest to get to are the idle jets. Do they jive with the sheet above?
After you closed your Fuel Mix Screws a turn, what is the status on the amount of Idle Speed Screw, did it change? Where is it now, how much of a turn in?
Main Jets 38/38:
Elevation:
Elevation:
Idle jets 38/38:
Elevation:
Will pull them tomorrow. I know I should have recorded them...
Boaf
Hey Dizzy,
I had the 32 / 36 on and it was very difficult to start and also backfiring out the carb (This before I replaced the Fuel Pump).
Not sure it is a coincidence that both carbs backfire out the carb and lack power. Thoughts? I'll pull the Idle jets out and read them tonight. Like Yourself, @Sarge, and @Pin_Head said A lean condition, but too much of a coincidence for a brand new 32 / 36 and a used 38 / 38 to perform the same. Ordered a fuel accelerator diaphragm as well.
Boaf
